- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Airplay, Sonos and Orbi RBR750 - UPDATED
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there -
I am having a problem with airplay - not only is it not working, but it is not even showing up as an option since getting the Orbi RBR750. I primarily use Airplay to play music over Sonos through Apple Music. I can use Sonos fine on its own, but it's interface is clumsy and I find it easier to use the Apple Music UI to play music.
My Sonos setup is 1 Amp connected to the router, 1 Play 5 (2nd gen), 1 Playbar and 2 Ones. They are all connected through Sonosnet. Airplay worked fine when I had an Airport Express, but since I switched to Orbi, Airplay has entirely disappeared. Is Airplay something the Orbi would affect? Is anyone else having this problem or have a solution? Any ideas?
Thanks,
Mike
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the solution was quite simple - unplug all sonos devices, reboot router, bring all devices back online!
Thanks to all!
Cheers,
Mike
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Airplay, Sonos and Orbi RBR750 - UPDATED
Is the Orbi SSID name the same as what you had been using on the previous router?
If you turn OFF Sonos devices and al RBS and just connect the Airplay device to the RBR alone, does it work then?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a SONOS BOOST as part of that architecture (or is a speaker hard wired) to get to SONOS net?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Furry -
Thaks for responding 🙂 The firmware is current for the router and the satellites (V3.2.16.6_1.4.4),
the modem is the ARRIS Surfboard SB200 DOCSIS 3.1 and the SSID is different. I'll try your other suggestion later.
Does that help at all?
Thanks!
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Chuck -
Thanks for responding! I do not have a Boost, but the Sonos Amp is hard wired to the router to create the SonosNet.
Thanks!
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope, only the Amp.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks to all!
Cheers,
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Airplay, Sonos and Orbi RBR750 - UPDATED/SOLVED
Good deal. Glad it is resolved.
Are you using S1 or S2?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please mark your thread as Solved by using the Solved button to let others know.
