- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BGW320-505 passthrough/RBR750 in router mode VS BGW320-505 Default/RBR750 in AP mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which is the recommended set up for the best performance? I am not a gamer. Just have a need for speed.
I have the gig ATT fiber with BGW320-505. I purchased the RBK753 from Costco.
What is better: (1) BGW320-505 in IP Passthrough and Orbi in Router Mode; or (2) BGW320-505 in default settings and Orbi in AP mode.
BTW, under either scenario, I would turn the wifi off on the BGW320-505.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BGW320-505 passthrough/RBR750 in router mode VS BGW320-505 Default/RBR750 in AP mode
either would function about the same.
the difference would be in what features you want.
When in ap mode, certain features are disabled on the netgear.
Same with the att router, certain features get disabled in passthrough mode.
so its which features do you use/want for your setup. Netgear's features or att's.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BGW320-505 passthrough to allow verizon network extender to connect / 2GIG alarm panel
Hello, I cannot seem to get either of the above devices to connect via my ATT modem/router. Tried the firewall settings, opening ports etc. Must be doing something wrong, any advice welocome. JS
- Mark as New
- Bookmark
- Subscribe
- Permalink
What Orbi model system do you have?
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@seniorj wrote:Hello, I cannot seem to get either of the above devices to connect via my ATT modem/router. Tried the firewall settings, opening ports etc. Must be doing something wrong, any advice welocome. JS
