Orbi WiFi 7 RBE973
Reply
Bitdefender Armor never connects
djunagi
I'm trying to get Bitdefender Armor on a MS Surface Studio laptop running updated win 11.  When it trys to login and check the license, the connection always errors out.  I have installed this on a few other devices I own and this is the only one causing trouble.
Message 1 of 5
Guru
Re: Bitdefender Armor never connects
You'll probably need to contact either netgear support or bitdefenders. This is the community support forum where members of the public help out.
For netgears:
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
Message 2 of 5
Patone407
Tutor
Have a look at the DNS servers setting that your MS Surface is using compared to the other devices which connected successfully.
Typically it should use the router or your ISP as the DNS server but if your device/computer has a different one then that will be the one used to lookup the IP address of a website you are going to.
Message 3 of 5
djunagi
@Patone407  I do have it normally running to the default dns servers provided by our AT&T modem .  I also tried directing dns to 1.1.1.1. and 2.2.2.2..  No difference as it still could not connect.
Message 4 of 5
Guru
What Orbi model is this?
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 575 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
