- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can I ethernet connect the old RBR50 in AP mode to the new RBR850 and broadcast the same SSID?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I upgraded my AC3000 mesh to the AX6000 mesh. I want to continue to use my Orbi Voice in the garage to listen to music and turn lights on/off with Alexa. Can I connect the RBR50 router to the new system in AP mode then have it broadcast the same SSID and continue to use the Orbi Voice and Alexa commands in the garage?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Something you can try bug it may cause problems. You should set a different SSID name and be sure to use far separate channels on each RBR. 1 for 2.4Ghz and 11 for the other. Same with the 5Ghz radios.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Can I ethernet connect the old RBR50 in AP mode to the new RBR850 and broadcast the same SSID?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Glad you got it working.
Ya, hidding SSIDs are not supported on Orbi AX.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@dklimas wrote:I upgraded my AC3000 mesh to the AX6000 mesh. I want to continue to use my Orbi Voice in the garage to listen to music and turn lights on/off with Alexa. Can I connect the RBR50 router to the new system in AP mode then have it broadcast the same SSID and continue to use the Orbi Voice and Alexa commands in the garage?
You can also connect the Orbi Voice as a wired Satellite to the Orbi AX6000 then you can have it as part of the mesh.
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750, Wired/Wireless Backhaul / Orbi RBR50 + 6x RBS50 + RBS40V, Wired/Wireless Backhaul | Switches Netgear GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Good to know but in my case I don't have ethernet in the garage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So it's more of an app thing and not a hardware thing? Or because the RBR50 is behind the RBR850 and in AP mode the RBR850 rules apply?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
A UI issue thats not seen on Orbi AX.
