- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Checking for firmware updates RBK753S
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I use the Orbi app, it says "There was a problem checking firmware update". When I use 192.168.1.1, it says "service unreachable".
The router and satellites all works fine, and I think the firmware is in fact up to date, but I didn't know if these error messages were something I need to worry about.
Thanks for any thoughts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Checking for firmware updates RBK753S
Sometimes it can be the ISP Modem you maybe connected to, other than this, sometimes it maybe NGs services that maybe at fault which we have seen before. Nothing to be worried about.
Best way to check for updates is to check NGs download support site.
There is a beta available which is made availalbe on request which is not on the download site nor on the update services:
- Mark as New
- Bookmark
- Subscribe
- Permalink
The firmware updated fine when I set up the orbi system, and I can always check manually for an update. I just didn't know why the app and the router ip address both gave error messages.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, just sometimes is a NG service issue. I did check mine last nite, didn't get a service error. So not sure why your seeing this. Anything is possilbe when it comes to Orbi.
Has a factory reset and setup from scratch been performed since last update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can save off a back up configuration to file, factory reset, check for FW update status on the RBRs web page and see if it still gives an error.
Re-load the saved config after checking.
