Reply
Differences between Netgear Orbi models?
gumpgump
Fairly recently, Netgear released their WIFI 5 Orbi product.   I kept an eye on it for a while and recently checked back to the site and blam, there are a few versions of this product offering -- but nothing that really describes what (if any) meaningful differences there are.  For example, the AX6000 must be purchased elsewhere -- is that because it's replaced by other models?   The number incrementing in product IDs doesn't really tell me anything.
So, does anyone know the real differences between these WIFI 6 Orbi products?
Thanks.
Message 1 of 2
Guru
Re: Differences between Netgear Orbi models?
I would download the spec sheets for the systems looking into and compare the data there.
https://www.netgear.com/support/
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK853 (Router Mode) | and R9000 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 368 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
