- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does Orbi Wifi 6 support DFS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not currently. NG doesn't make it known if or when new features are forth coming. I presume since Orbi AC doesn't have DFS features, Orbi AX will probably follow suit.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does Orbi Wifi 6 support DFS?
Orbi and Orbi AX does make use of the DFS channels for the wireless backhaul operating on a high channel set, while the front haul is indeed using the non-DFS range. Operating front and backhaul to near together (both on a neighboring 80 MHz block) does not make much sense for interference reasons.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Makes sense - but in an environment where I use 100% wired backhaul, I would not use Orbi's wireless (DFS, high channel) backhaul, and thus would want to be able to utilize DFS user facing...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Kyne wrote:in an environment where I use 100% wired backhaul, I would not use Orbi's wireless (DFS, high channel) backhaul, and thus would want to be able to utilize DFS user facing...
Well, in that wired backhaul-only set-up you might want to use both 5 GHz radios for the fronthaul. This was requested on Orbi and Orbi Pro - it was not considered to be added to Orni, so it's not there on Orbi AX either. On Orbi Pro both 5 GHz radios (the low and the high band one split to lower and higher channels to avoid interferences) are both configureable. You might want to search the Idea Exchange for Home thread, convinced there are already similar ideas filed for Orbi, which should be applied to Orbi AX, too.
