- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does the RBR750 support DHCP option 121 ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am connected to the Starlink satellite system. They provide a very basic router and don't allow you to make any settings. I have my Orbi RBR750 connected to the Starlink router's aux port so that I can see Starlink's statistics but that of course creates a double NAT. It has been reported that if your router supports DHCP option 121 you can eliminate the Starlink router and still see the stats. I haven't been able to see the stats if I disconnect the Starlink router. Is there a setting I need to turn on to enable DHCP option 21 or does the Orbi not support it? Thanks for any help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does the RBR750 support DHCP option 121 ?
I don't believe so.You might check the user manual for any info.
Does the Starlink router have a DMZ by chance? If it does, you could use this for the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like we're stuck with using a static route to access Starlink's stat pages. Thankfully it is super easy to do. If you are still wrestling with this let me know.
