Orbi WiFi 7 RBE973
Reply
Failed to Connect error when trying to run Speed Test for Orbi850 from my iPhone
Bluewater24x7
Speed Test Connection Failure Orbi850
Unable to connect from my iPhone for a speed test on my Orbi RBR850. I saw posts from 2018 but nothing recent. I have rebooted the Orbi, reset it and done everything else I can think of and I still get the error. Suggestions?
Message 1 of 4
Guru
Re: Failed to Connect error when trying to run Speed Test for Orbi850 from my iPhone
What mode do you have the RBR in? Router or AP mode?
Does the speed test app run from the RBRs web page?
Message 2 of 4
NormalJim
Same issue here;
It happened post Firmware update to V3.2.16.6.
It's annoying, but router seems to function OK...
Message 3 of 4
Guru
Does the speed test run from the RBRs web page?
@NormalJim wrote:
Same issue here;
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 524 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
