Reply
Firmware v3.2.10.11 Frequent Disconnects
joshadam1984
Hello. Over the past couple months I’ve noticed frequent disconnections from a couple of my RBS850 satellites. I have three satellites in all.. with a stand-alone modem (Only) and the RBR850 as my router.
I took the feedback from other posts and downloaded a much earlier firmware version yesterday evening, did a hard reset, and started fresh.
Unfortunately, the system updated over night last night on its own back to V.3.2.10.11.
When I noticed that this morning, I once again did a hard reset on the router and satellites. I’ve hard the “updated” system running for 3 hours now and maintains frequent disconnects from the RBS850s.
Everything worked seamlessly up until about the middle of March.
Any recommendations or assistance is appreciated. Also, I did go back and update the thresholds to the 2347 value.
Thank you.
Message 1 of 13
Guru
Re: Firmware v3.2.10.11 Frequent Disconnects
Have you loaded v11.2 on everything then factory reset and setup from scratch, set CTS/RTS values to max then see if problem reappears?
https://community.netgear.com/t5/Orbi-AX/RBK852-Firmware-Update-V3-2-11-2-1-2-13/m-p/1904045/highlig...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX80 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 13
joshadam1984
I should all that none are wired.. all wireless. When synced, they flash blue.. which I understand is a good connection.
Message 3 of 13
Guru
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Message 4 of 13
joshadam1984
I haven’t adjusted the channel— it is auto currently so will try changing it.
Wifi neighbors— normally 1 sometimes 2 show up.
One is more then 30 ft, blue does flash blue when syncing.
I did a factory reset after it automatically pushed the firmware back to v3.2.10.11.
CTS/RTS were changed and all Orbi systems rebooted.
Message 5 of 13
Guru
Try v11.2 if needed.
Message 6 of 13
FarmerBob1
Luminary
Yesterday I was having all kinds of trouble after being in 11.2 for a while and IoT Devices that work fine on their own, but weren't interacting with eachother as they should. I did a Back-Up and a Factory Reset in preparation for reverting to 10.11 from 11.2. As I was getting ready to load 10.11, I realized that when I installed 11.2 I didn't do any of the "adjustments" that I have discovered needs to be changed. So I restored with the Back-Up that I just made, then turned off CoEx. Alexa is not only talking to my kinda old AV gear, but changing settings and inputs.
Just for giggles, try just turning off the 2.4GHz/5GHz Coexistence setting. That has fixed these issues many times for me. The next thing to try is turning off AX Features. After I did the restore I started off with CTS/RTS is at 64, the default. I also have left the channel at "Auto". Which with Netgear, they usually do a pretty good job of dodging congested frequencies. That is "usually". But with the changing of the Coex, I upped the CTS/RTS to the max of 2347. Preamble at "Automatic", was "Short", and Power 100%. The third thing I do is turn off WMM (Wi-Fi multimedia) settings on both 2.4 & 5GHz. This has come from the step by step trouble shooting I have had to do.
Let us know what happens . . .
Stay Smart, Safe & Well . . .
. . . fb
Sir ORBI · "Defender, Protector and Provider of WiFi to the peasants . . .
"Resurrector of the 30-30-30 & creator of the DFWI"Dreaded FW Install".
My Stuff | ISP Qwest Legacy Fiber via Centurylink | Speed 940/940 through a Calix 716GE-I R2 ONT connected directly to: | WiFi Router ORBI RBK853 (for now) | 2 Sats on Wireless Backhaul | Sending out to all corners of the kingdom . . .
"It's not over until the Dragons are done strafing the lands and there's no spilled beers."
Message 7 of 13
joshadam1984
Has there been good feedback on the 11.2 version? I will definitely look into manually updating it to 11.2 if so.
Also, it really seems to be isolated to one of my RBS850 satellites as opposed to the RBR850, itself. I say this because I was still able to work on my laptop.. which was connected to the router.. however, our living room Roku was consistently disconnecting.  This Roku was connected to one of the RBS850 satellites. I tried a wired and wireless connection and it kept occuring. As a result, I swapped the placements of two of the RBS850 satellites with one another and the Roku has held on strong for the last 3 hours whereas before it'd disconnect every 30-45 mins.
If I can isolate it to the one satellite having the issue then certainly could assist in potential troubleshooting.
Thank you!
Message 8 of 13
joshadam1984
Thank you for the detailed troubleshooting options, fb. I'm trying to see if it may just be limited to one of the satellites having an issue as opposed to the RBR850, itself. I'll keep you all updated after I replace them a few times and see how long they stay connected.
Are there any easy ways of monitoring satellite disconnections?
Message 9 of 13
Guru
I haven't seen any disconnects with my system on v11.2.
The only problem is that the backhaul status reporting in the RBR in broke while the RBR is in AP mode if you connect RBS to the RBR with a Gb lan switch in the middle. Smiley Frustrated
Message 10 of 13
Sevo123
Apprentice
Im on version 3.2.11.2 and my devices are disconnecting constantly its so annoying! I regret buying my rbk853 and giving netgear $1000 smh !!!! Do upset that they cant fix this stupid disconnecting issue. Before on my rbk53 unit they did the same thing in the beginning then finally fixed this situation now a new product and new problems... Their phone support is garbage now. They cant even help
Message 11 of 13
Mikey94025
Hero
It is certainly frustrating that your home network is not reliable for you.  Do you have a posting where you can describe your issues and get community assistance?  I think everyone's situation is different so we cannot assume that one person's disconnects is the same as another's
I've been fortunate and my AX system has been great with both 3.2.11.2 and the prior 3.2.10.11.   Once I changed CTS/RTS to 2347 (thanks FURRYe38!) then things worked as expected.
Message 12 of 13
Guru
Is the Orbi system operating in Router or AP mode?
 IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 1082 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 6E
