Orbi WiFi 7 RBE973
Reply
Guest Network is slow
mbarylski
Guide
I'm having problems with the guest network. The connection is fine, and speeds show that everything is working, but apps aren't connecting. It's really slow or buffers forever. There don't seem to be very many settings available to configure, so I'm not sure what else I can do to fix it. Any suggestions?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 56
Guru
Re: Guest Network is slow
What model Orbi do you have?
Message 2 of 56
mbarylski
Guide
I have the RBR850 with the latest firmware connected to Verizon Fios. It seems to work off and on. Not sure why. If I disconnect and reconnect the WiFi guest network it works, but it doesn't persist. After awhile it stops working and I have to drop the connection and reconnect again.
Message 3 of 56
mbarylski
Guide
What do you mean update my signature line? With what? Model of my orbi?
The modem is the Verizon Fios ONT. It's all built in to their outside box, and the CAT6 just runs to the Orbi. So all I have is the Orbi, and WiFi is coming from the Orbi.
Btw, I noticed that switching WiFi on and off doesn't always work either. I have to switch off the private connection and switch it back on.
Message 4 of 56
mbarylski
Guide
Yea, I know, because Netgear doesn't list the model I have as an option. Not much I can do about that. I believe the 50 is the same as the 850 though which is why Netgear isn't listing a separate model.
Appreciate the links, but I've already set up Orbi with Fios. It works fine. It's the guest network that doesn't work reliably. There's nothing in the documentation that talks about how to specifically configure the guest network. It does seem though that the documentation shows more options than what's actually available though, which is odd.
Any idea why connection via the guest network is unreliable?
Message 5 of 56
mbarylski
Guide
no...the 850 is a WIFI6 model...different beast
https://kb.netgear.com/31579/How-do-I-set-up-a-guest-network-on-my-Orbi-WiFi-System
Am I in the wrong forum then? I can't seem to find the correct place to post.
Message 6 of 56
mbarylski
Guide
@vajim wrote:
if you have the 850...you're in the right forum...
Ok, thanks. Any suggestions on how to get some help with this one? I can't open a ticket with Netgear cause my support expired, but this seems like a bug.
Message 7 of 56
Mikey94025
Hero
What kind of device are you seeing this problem and are you having this guest network problem with one or many devices (phones)?  Does this problemmatic device work just fine when connected to the regular wifi instead of the Guest wifi?
What settings have you changed from the Orbi defaults?
Try this:
  1. Go to the web admin interface at http://orbilogin.com
  2. In the Basic tab, click on Guest
  3. Try changing Security Options between "WPA2-PSK [AES]" (recommended) and "WPA-PSK [TKIP] + WPA2-PSK [AES]"
Another thing to consider if you're still having issues and your Guest network issue is with 2.4ghz - In my experience the following improves Orbi AX wireless compatibility with older 2.4Ghz devices:
  1. At orbilogin.com, go to the Advanced tab, Advanced... Wireless Settings
  2. Set CTS/RTS Threshold for both bands to 2347
Message 8 of 56
mbarylski
Guide
Try this:
I appear to be having issues with all devices. I first tried with iPhones and those will connect sometimes, but require switching private connection on and off. I just tried with my day-to-day Android and it doesn't get an Internet connection at all, but it works on the regular WiFi.
I did try the different security options, but that didn't work either. I didn't change the CTS/RTS threshold, because I'm testing on a WiFi 6 Samsung Galaxy S20.
So strange that I'm not getting any internet connection. Does the guest network work for you?
Message 9 of 56
Mikey94025
Hero
Yes, my guest network works just fine.  I can't think of what could cause devices to not connect to the internet or be slow via your Guest wifi, but work fine on your regular wifi.
At this point doing a Factory Reset and starting over may be recommended and to ensure everything is cleanly setup again.
Message 10 of 56
mbarylski
Guide
Are you using Access Control? Maybe that's what's interferring with mine.
Message 11 of 56
Guru
I would factory reset the RBR. Turn OFF the RBS for now. Setup the RBR and don't enable Access Controls, Armor, or Traffic Meter. Setup Guest network, you might set OPEN security first temporarily. Then connect your devices and see how the performance is. Then enable WPA2 and AES only and retest. See how the performance is...
Message 12 of 56
bdsmith63
Apprentice
I just setup the new RBK753 AX4200 Mesh System, did not enable Traffic Meter or Access Control, Armor is enabled.
Regular WiFi network is working excellent, no hiccups.  Had two of my kids over last night, one had their MacBook Pro laptop connected, their Samsung Galaxy Note (WiFi6) and my son's iPhone 11.  All devices connected to my Guest Network were having issues, could get connected, they would loose connection or be slow, same issues as above, there must be something going on with the latest firmware version on all these Orbi Mesh systems with the guest network.  Being I bought a new system, I should be able to open a ticket with support?
This is VERY frustrating.  I ended up connecting their devices to my regular WiFi and perfect connections with no issues.  (I had this same issue with the RBS50/RBR50 AC3000 System).
Message 13 of 56
Guru
Please open a support ticket.
Also contact a forum moderator and ask about a beta that is available to see if this helps any.
@Christian_R
Message 14 of 56
mbarylski
Guide
Yes, you definitely can open a ticket. Sadly, my free support period has ended so I'm not able to open a ticket. I hope you do though so they can fix this issue.
Keep us posted. 😁
Message 15 of 56
bdsmith63
Apprentice
I will definitely open a ticket as soon as I can get to it.  Thanks and will keep you all posted.
Message 16 of 56
Guru
Have you reached out to a forum moderator? Please ask about a beta version of FW.
@Blanca_O
@Christian_R
Keep us posted. 😁
Message 17 of 56
bdsmith63
Apprentice
Thanks, I will follow-up on this, who do I reach out to the forum moderator?
Message 18 of 56
bdsmith63
Apprentice
I figured it out -- messages have been sent to the moderators!
Message 19 of 56
Guru
Select there user name and then send them a message on there profile page.
Message 20 of 56
bdsmith63
Apprentice
As an update to this thread, I contacted Netgear support this morning and opened a case regarding the issues with the guest network running on firmware 3.2.18.1 on my RBR753/RBS753 system.
After going through all the troubleshooting steps, we reverted back to firmware 3.2.17.12 for the router and satellites.  I have been testing devices for over 3 hours now with no hiccups.  Support said to report back in 24-48 hours and they will escalate my case regarding the issue with the latest firmware.
Message 21 of 56
mbarylski
Guide
Wow, that's interesting. If the old firmware works, I hope they're able to identify the issue quickly and fix in the next update.
Just in case this isn't a quick fix, how'd you drop back to the old firmware?
Message 22 of 56
bdsmith63
Apprentice
Just to the Netgear downloads page:  https://www.netgear.com/support/download/
After I downloaded the previous version of the firmware for the router and satellites, you just go into the manual upload section of your firmware update on your Orbin login.  I used a laptop that was wirelessly connected near the router.  I did the router first, then the satellites.
So far I've tested loading the guest network and haven't had any issues.
Message 23 of 56
mbarylski
Guide
Awesome, thanks!
Message 24 of 56
Guru
Im wondering if the newer beta FW has the same problem as well or not?
Message 25 of 56
Top Contributors
Discussion stats
  • 55 replies
  • 4569 views
  • 8 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
