Reply
Help Build Home WiFi Mesh For Cox Gigablast
JA99
Follower
I'm hoping for help. I'm upgrading to Cox Gigablast and want to install Orbi RBK853 WiFi 6 System for a wireless mesh. I've looked at the Cox website to see what modems are compatible with Gigablast, and the CM1200 Nighthawk is on the list. Are there connectivity/compatibility issues between the modem and router models noted? If seamlessly compatible, is the CM1200 modem a good choice for the Orbi router mesh noted above? My home network is used primarily for internet surfing, TV streaming, and gaming. We do not currently use voice activated devices.
I appreciate your feedback.
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem
Message 1 of 3
Guru
Re: Help Build Home WiFi Mesh For Cox Gigablast
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
The CM1000, CM1100 or 1200 will be good modems.
Good Luck
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router SXK30(v.122) and R8500(v.158) Router Mode and Wired Backhaul | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 3
Guru
Let us know what you end uo getting...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1576 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
