Reply
How to clear all entries from device connected table
larryindublin
Luminary
Is there a way to clear all the device connected entries from my RBK753 (1 router, 2 satellites). Will simple power off of all 3 do it, or do I have to do a full reset?
Message 1 of 3
Guru
Re: How to clear all entries from device connected table
Is this on the RBRs connected devices list?
What browser are you using?
The RBR should auto clear devices if they are not connected I believe.
A full power OFF and back on as well should do it.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 3
Guru
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact @Blanca_O and @DarrenM and send them a PM and ask for the beta.
https://community.netgear.com/t5/Orbi-AX/New-RBK752-753-Firmware-Version-4-6-3-7-Released/m-p/213650...
https://community.netgear.com/t5/Orbi-AX/New-RBK752-753-Firmware-Version-4-6-3-7-Released/m-p/213652...
Good Luck.
Testing
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 133 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
