Orbi WiFi 7 RBE973
Reply
How to use the ethernet port on orbi satellite of RBK753S-100NAS
lxu2011ct
I have the system RBK753S-100NAS just set up with one route (RBR750) and two satellites. The three are connected wirelessly with good connection. I connect a NAS on one of the satellite through its ethernet port, but cannot see it on the network. I searched online but cannot find clear information how to use the ethernet port on the Satellite. It seems like that in order to use the ethernet port on the satellite, the satellite has to be connect to the route by wire. is it correct? Thanks.
Message 1 of 12
Accepted Solutions
Guru
Re: How to use the ethernet port on orbi satellite of RBK753S-100NAS
Ok, just checking.
Please remove any static IP address configurations on the NAS and set Dynamic or Auto obtain IP address configuration on the NAS.
Message 10 of 12
All Replies
Guru
Please visit and post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
The RBS can be synce wirelessly or by wired to the RBR.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
You can connect other wire devices to the back of the RBS as well.
Thank you.
Message 2 of 12
CrimpOn
Guru
No, this is definitely not correct.
Does the Orbi web interface Attached Devices screen not show the NAS as connected?
Message 3 of 12
Guru
I believe the power is referencing the RBS model# which includes a NG-NAS nominclature that refers to a marketing region that differs from NAS being Network Access Storage.
Message 4 of 12
lxu2011ct
Yes, I cannot see the NAS on the Netgear home page of the router, neither of the satellite. Thanks.
Message 5 of 12
Guru
Can you see the NAS unit when it's connected to the RBR?
Seen others post about having the NAS connected to the RBS and they can't see it. Mines not connected to the RBS, rather behind the RBR.
Message 6 of 12
lxu2011ct
I moved to the route and I can see it now. But it is not stable, sometimes disappeared then appeared again. One thing I noticed is its IP address: 10.0.0.200, not the one 192.168.1.x. Is this a problem? How do I force it to change the IP address to 192.168.1.x? Thanks.
Message 7 of 12
Guru
Yes.
Means that your RBR detects a router up stream that also uses 192.168.1.1.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 8 of 12
lxu2011ct
I don't have two routers. The provider is Xfinity and the cable modem is Motorola MB8600. The Netgear Orbi home router connect directly to the Motorola Modem. I think the NAS has the assigned IP address with the previous router. But it's long time ago, I cannot remember. Thanks.
Message 9 of 12
Guru
Ok, just checking.
Message 10 of 12
lxu2011ct
Yes, after change the NAS static IP to dynamic it can connect to Orib constantly. Thanks.
Message 11 of 12
Guru
Glad you got it working. Enjoy.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2366 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
