- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Looking for help for LACP/Vlan configuration for RBR750/CM2050V/GS110EMX
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have the following equipment all Netgear GS110EMX switch, Orbi RBR750, CM2050v Modem. What I have been trying to do is use the GS110EMC switch to create a seperate VLAN2 (Port based) with just the the RBR750 (Using LACP) to the switch and the Multigig 2.5gb port from the CM2050v modem in vlan2.
What I am seeing is if I create the vlan and plug 1 port from rbr750 and the 2.5gb from the modem I get connectivity for bit. If I then enable my LAG on the switch and turn on the LACP on the modem the RBR750 doesn't seem to be able to get the DHCP from the CM2050v even though the switch says the LAG is good. If I remove the LACP and leave one of the RBR ports connected I still can not get the DHCP to work through the switch. Once I lose that IP I have to totally remove the cables from the switch and connect directly and then reboot the modem and the Orbi to get it all working again.
I hope that made sense and someone can point me in the right direction. My internet provider is Comcast and my speed is supposed to be 1.2gb which I why Im attempting to go above the 1gb. BTW. I have my NAS running on a LAG in the other vlan on the switch with no issues. I am using the Orbi as the DHCP server in Router mode as I use the guest network for my IOT devices so I haven't tried as an AP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Looking for help for LACP/Vlan configuration for RBR750/CM2050V/GS110EMX
Please refer and post about this over in the manage switch forum:
https://community.netgear.com/t5/Managed-Switches/bd-p/business-managed-switches
Good luck.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks, I debated on where to post it but I was guessing the issue is with the Orbi but I'll try.
