Orbi WiFi 7 RBE973
Reply
Low network speed on one satellite (out of 2) - Orbi WiFi 6 System (RBK853) AX6000
EyalS
Tutor
When connected to one of the satellites, either WIRED or wireless, I'm getting a maximum of 5mbps. Tested on a desktop with https://www.speedtest.net/.
When replacing the satellite with a switch, I'm getting again 80mbps (wired).
Same happens with iphone 11 pro. It gets a maximum of 5mpbs when connected to this specific setellite. and around 70 mbps when connected to the other satellite or the main router.
Someone have an idea what could cause that?
10x,
EyalS
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Accepted Solutions
Guru
Re: Low network speed on one satellite (out of 2) - Orbi WiFi 6 System (RBK853) AX6000
What are you results of the other RBS?
Press the back reset button for 15 seconds then release.
Message 2 of 4
All Replies
Guru
Message 2 of 4
EyalS
Tutor
Factory reset fixed the problem. Thanks.
Message 3 of 4
Guru
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1014 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
