- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lower DL Speeds & Frequent Disconnects After Firmware Update to V4.6.3.7
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello, I have a RBR750 Router + Mesh System (3 satellites) and ever since updating to the new firmware in July (V4.6.3.7) I've had persistently slower DL speeds (from 900 to ~600 Mbps) and the router and satellites have been regularly cutting out and resetting throughout the day (which has been brutal).
I know there's another post around slower speeds, but wondering if anyone has had issues with devices dropping or resetting since this update if there are any troubleshooting tips to resolve.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
NG doesn't let us know when new Fw is coming out so will have to be patient. Hopefully sooner then later.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router SXK30(v.122) and R8500(v.158) Router Mode and Wired Backhaul | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Lower DL Speeds & Frequent Disconnects After Firmware Update to V4.6.3.7
This is a known issue that NG is aware of. It effects the speed results on the RBRs internal speed test app.
Use a external speed test app with a wired PC and you should see near 900Mpbs if that what you pay for from your ISP.
Also disable AX mode on the RBR. Users have posted this is helping there systems in mean time.
Hopefully should be fixed in next FW update. Please be patient.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks. Is the just pertaining to the bandwidth issue, or does it also result in the devices consistently resetting and losing signal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Both.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ah good to know, thanks for the follow up.
Is there any estimate on when the next FW update will be? This is a pretty bail #fail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
