Orbi WiFi 7 RBE973
Reply
Need to connect One Orbi RBK85 router with 5 Orbi RBS85 satellites using LAN cable and switch
tahaasha
Follower
The model I purchased is not found in the list, so I:m adding the details here
Orbi RBS850 count 5
Orbi RBR850 count 1
Windows 10
Ver 2.8.5.15
I want to connect 5 satellites and 1 router to a switch as access point or bridge mode like apple airport extrema, is it possible ?
Message 1 of 2
Guru
Re: Need to connect One Orbi RBK85 router with 5 Orbi RBS85 satellites using LAN cable and switch
You'd probably find the model (and better helps) on the orbi AX forums.
Home Networking - NETGEAR Communities
But that model does support a wired backhaul.
What is Ethernet backhaul and how do I set it up on my Orbi WiFi System? | Answer | NETGEAR Support
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 318 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
