Reply
Netgear Orbi AX6000 and adding a Nighthawk AX12 (AX6000)
fluxis
I have a Nighthawk AX12 (AX6000) right now and its not quite giving me the range I need in my house.
I am looking to buy a Orbi AX6000 2-pack but instead of just selling the AX12 I have now I was hoping to use it in the mesh.
Is there a good way of doing this that won't cause more harm then benefit?
Maybe its just better to buy another AX12 and create a mesh out of that?
Message 1 of 4
Guru
Re: Netgear Orbi AX6000 and adding a Nighthawk AX12 (AX6000)
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 4
fluxis
Not sure on the model number for my ONT but its Verizon Fios gigabit.
I have a ~2400 sq ft home but the problem really is its a townhome as is 3 floors so the plan is basically a single device per floor.
Message 3 of 4
Guru
Would be something you may want to try with the Orbi AX system, find a place that has a good refund policy and take one for a demo ride and see how it works for you.
Testing
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 138 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
