- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - RBK752/753 Firmware Version 4.6.3.7 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RBK752/753 Firmware Version 4.6.3.7 Released
Would you list us the FW version they gave you please?
@AK_NG wrote:
I finally got a call from netgear customer support with a beta FW ver . I was able to update to new beta fw ver manually for the mesh and the slowness issue is resolved. The speeds are now consistent in 900 mbps . Did not notice any issues for past day or so with new beta ver which is a good news.. Hopefully netgear will send new ver fw to others also that are facing issues with new fw update soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok thank you. I'll direct users to NG support and ask about this. Lots of users hopefully will benefit from this.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact @Blanca_O and @DarrenM and send them a PM and ask for the beta.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see you posting this all over, to contact support, but maybe you should contact support to let them know a Beta is available becuase I just did and they don't know about the beta and don't have access to it. Just spent 30 minutes with them and they have no clue.
So people, don't contact support, they don't know about the beta and it will just result in a waste of your time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just received and installed the 4.6.3.16 beta fw release from NG Support. Its been running for an hour now without issues. For sure too early to tell but it is looking good.
Unfortunately the beta release can't be shared in the forum as the user has to agree to some usage terms before downloading it, this is painful but understandable. I am quite sure that if you open a ticket that refers to the 4.6.3.7 fw issues, it should not take longer than a day before you get access to the beta fw.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the Beta release comes with an update for both the RBR and the RBS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyone know how to submit a case if you are out of warranty and beyond the generous 90 day support? Do you try the request to replace?
I'd also be curious if anyone who has the beta installed if they've had the internet disconnects and the router going non responsive and the light turning magenta if this release addresss it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for confirming and letting us know what the process is and the results. Hopefully the beta and a follow on FW update will fix all this.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please reach out to the forum moderators if your beyond warranty support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, even though i was beyond the 90 days support, but within warranty i choose the request for replace option. Shortly after i was on the phone with NG support and during that call they converted my case to a proper support case (as you would get when you are eligable for support). This case was then followed up by NG. Because of the time difference i got calls at impossible moments, never the less i was able to progress just by updating the case. I have to say that even though a long time went by since logging the case (started at August 19th) we are now very close to a solution.
@Timothy88 wrote:Anyone know how to submit a case if you are out of warranty and beyond the generous 90 day support? Do you try the request to replace?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just installed the beta firmware that I received through support. The intermittent disconnect has stopped but it has only since a few hours since the firmware "update." I'll report back in a few days whether this seems to have resolved the issue.
PS I did not change any of the settings after installing the beta firmware including the wifi6 AX options.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know. Let us know how it goes later on down the road.
- Mark as New
- Bookmark
- Subscribe
- Permalink
