- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - RBK752/753 Firmware Version 4.6.3.7 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RBK752/753 Firmware Version 4.6.3.7 Released
For troubleshooting sake, yes, it's not recommended to use a back config initially.
Try a reset and setup from scratch. Try setting manual channel 1,6 or 11 on 2.4Ghz and 40 to 48 on the RBR.
I would set up the RBR first then bring the RBS to the same room as the RBR and sync them 1 at a time. Let us know if they don't sync and don't remain connected
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No problem before update….
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update?
Factory reset or anything else will not resolve this issue.
I spent numerous hours with TS, performing many tests, reviewing logs, etc. They sent out a replacement RBS750 Satellite, for the damaged unit. However the RBR750 router is going to pulsating whte, several times per day. There is no way to downgrade and I manually re-loaded the 4.6.3.7 firmware, hoping it would help. It didn't help.
After extensive troubleshooting, along with tech support, I strongly feel this is also caused by the pushed 4.6.3.7 firmware update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same here. For months i have used the system without any issues (Router and 3 sattelites, 1 wired, 2 wireless in daisychain). After the 4.6.3.7 fw update the whole system is unstable. Wired everything is fine but wireless there are disconnects trhroughout the day. Also devices will not automatically reconnect to the orbi wifi. I don't feel like resetting everything, i just hope a fw update will be available soon...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The solution to all of these problems could be so easy if Netgear did not avoid downgrading firmware !
There firmwares are plenty of bugs and not well tested before release.
We will maybe have to face many other issues with some of upcomings firmwares.
Why are they blocking downgrades so that we can downgrade to a more stable firmware in cas of issue with latest release ???
We are not talking about low cost hardware so we might have the right to choose which firmwareversion to use.
I really don't understand why they are doing this.
But for sure I don't think I will buy Netgear again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I fully agree, invested nearly 1k in this equipment. it will make it harder to reccomend this to friends and families for sure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And the real sore spot is, even thought it is clearly Netgear's fault, they are charging shipping for replacing under warranty gear. They should be replacing it for free including shipping. And only charge shipping for out of warranty gear that was affected, but still replace for free. I cannot charge my customers fees for something that is not their fault.
There has to be a reason for not allowing the downgrade. I'm assuming it has to do with the WIFI WPA-PSK [TKIP] + WPA2-PSK [AES] security issues they got hit with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you made contact wtih NG support about this yet? If not, please open a support ticket as it seems theres nothing else we can help with here in the forums.
@Mstrbig wrote:And the real sore spot is, even thought it is clearly Netgear's fault, they are charging shipping for replacing under warranty gear. They should be replacing it for free including shipping. And only charge shipping for out of warranty gear that was affected, but still replace for free. I cannot charge my customers fees for something that is not their fault.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just factory reset everything as i had to do something. Why is it that during the setup the router seems to already know my custom sattelite names? (also not had to sync them again).I have not restored anything and reset all 4 devices with a paperclip until the blinking orange light... btw. The disconnects are already happening again. No i have not contacted support yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please open up a support ticket and contact NG support and let them know what your experinecing.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto?
@Berryvl wrote:I just factory reset everything as i had to do something. Why is it that during the setup the router seems to already know my custom sattelite names? I have not restored anything and reset all 4 devices with a paperclip until the blinking orange light... btw. The disconnects are already happening again. No i have not contacted support yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Please open up a support ticket and contact NG support and let them know what your experinecing.
Really?
Its not that i am not willing but it seems my complementary support expired in april, but i can get a hw replacement.
My hw is not defected, my sattelites are placed correctly and the frequency were never an issue. The issues i see now started directly after upgrading to 4.6.3.7 the day before (and months) everything worked really perfectly. minutes after upgrading the disconnects and instability started to happen.So all the questions asked above are not relevant as with 3.2.18.1 everything was fine and so far i was really happy with NG and the Orbi's, recommended it to friends, colleages and family.. but i am starting to feel sorry for that.
I think NG has to acknowledge there are issues with the 4.6.3.7 version and fix it as soon as possible instead of stringing everyone along to open support tickets.
At this moment my household is disrupted becaues of this. Already spent hours trying to fix it myself. This is not what I was buying into when i orderd the RBK753. Of course bugs exist but this feels as if SQA failed and 4.6.3.7 was not properly tested before the release.
So rather than asking everyone to open tickets, please look into it yourself, it is unimaginable that NG is unable to reproduce these issues withing Support/Engineering.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Again, this is something beyond forum help and support so you'll need to inform NG support of what your experiencing.
Good Luck.
@Berryvl wrote:Really?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok i will do that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think that factory reset doesn't seems to fully reset all settings.
I have done Hard Reseting many times on each device, for me it seems that some parameters are maybe stored in a memory like nvram and are not resetted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Instead of trying the reset button, try using the ERASE function on the RBRs web page. Under Advanced Tab/Advanced settings/Backup. See if this clears out all of yoru configurations from the RBR.
Be sure to also clear out all browser caches after you trigger the ERASE.
@Berryvl wrote:I just factory reset everything as i had to do something. Why is it that during the setup the router seems to already know my custom sattelite names? (also not had to sync them again).I have not restored anything and reset all 4 devices with a paperclip until the blinking orange light... btw. The disconnects are already happening again. No i have not contacted support yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have now factory reset all units twice, once restoring settings, and once setting it up manually. Both lead to the same outcome - constant disconnections, and satellites losing sync.
Support is unhelpful, as they go through the motions on troubleshooting, but don’t / can’t review logs to find the real source of the issue.
As rumbles grow across multiple people, the issue is obvious - the v4.6.3.7 firmware is not ready for prime time. Whilst mistakes in QA testing happen, it’s pretty infuriating that there is not an option to roll back to previous firmware.
Netgear should acknowledge this issue, work with some users to really understand the problems, and push a firmware fix urgently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This kind of product is designed for Home needs and should be Plug and Play :
- easy configuration
- forget it and let it running
At first installation whith Orbi App I was hoping a Plug and Play Orbi system but I had to do the configuration and Hard reset many times because of many issues like satellite not discovered even when just near from the router or because of app issue not finishing the configuration.
Hardware is good but software is plenty of bugs.
For sure I would not recommand Orbi system to friends and my family because it needs to have minimal technical skills and take too much times doing configuration and troubleshooting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Niko78 wrote:I think that factory reset doesn't seems to fully reset all settings.
Try a 30 30 30 FACTORY RESET.
First do a backup of your settings, as you will lose them.
Do this one at a time, starting with the router
While the device is plugged in, hold the reset button in for 30 seconds
Unplug the device, while holding the reset button in for 30 seconds
While holding the reset button, plug in the device, and count another 30 seconds.
Your device should be cleared of all settings and configured back to factory settings.
This usually fixes unexplained errors like WIFI issues, devices not connecting etc.
But unfortunately, it will not repair a bricked device, where the firmware flash got corrupted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This whole upgrade has been a nightmare. I cannot believe NG is blocking a downgrade. I had to redo everything twice and stuff is still randomnly dropping off WiFi. Wired has been fine thus far (knock on wood) but I have zero confidence in this. I upgraded from the 50 and will probably return my 753 setup to Costco (if I still can) and get something else or see if I can go back to my 50.
Heck, I might dig out my old Unifi stuff and set that back up. I got this to be plug and play working for my wife and kid when I'm not away. I've spent more time dealing with this fiasco upgrade in the last couple of weeks more than this is worth.
How does something like this make it through the QC process?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What CTS values are you using?
Is Smart Parental Controls enabled?
@Jeff-531 wrote:This whole upgrade has been a nightmare. I cannot believe NG is blocking a downgrade. I had to redo everything twice and stuff is still randomnly dropping off WiFi. Wired has been fine thus far (knock on wood) but I have zero confidence in this. I upgraded from the 50 and will probably return my 753 setup to Costco (if I still can) and get something else or see if I can go back to my 50.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just an update to my issues - they're still the same, but I can also see that the satellites are acting up as well; disconnecting and re-connecting. I see that it has been mentioned by someone else here too.
I've been told twice that NG support will contact me, but still haven't heard anything yet.
It's too bad, as I still think that the Orbis was a good match for my home until this new FW.
I've tried all the tips mentioned in this thread without any luck.
After a while I also thought it could be my network provider having faulty equipment on their side, but got great support from them clarifying that it's all on my end.
Still thinking that with a fix I'd keep the Orbis, but if this is a sign of what one can expect after FW releases, I'm quite sceptic.
