- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - RBKE9 Series - RBRE960 / RBSE960 Firmware Version 6.0.3.82
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bug Fixes:
- Fixes the issue where the WAN connection setup with an Arris/Pace 5268AC modem fails.
Download Link:
https://www.netgear.com/support/product/RBKE963.aspx#download
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBRE960.aspx#docs
For Manual FW updates:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli...
NOTE: After the FW files are loaded and the RBR and RBS is ready, power OFF the RBR and RBS for 1 minute then back ON. Unplug the power adapter from the power wall outlet then back in.
If problems are seen after a FW update, a factory reset and setup from scratch maybe needed:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
This article applies to:
Let us know how it works for you...
