FURRYe38's avatar
New - RBR750 / RBS750 Firmware Version 4.6.11.1 Released
Enhancements: 10/06/2022
  • Add Canada region support for RBK65x series Orbi systems. (RBR750 with RBS350)
Security Fixes:
  • Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Download Link:
https://www.netgear.com/support/product/rbk752.aspx#download
Please navigate to the link below for step-by-step instructions on how to update your RBR750/RBS750:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
NOTE: The Disable Auto Update feature only prevents ANY new FW from being installed if available. This does NOT prevent the system from checking NG services to see if new FW is available. If new FW is available, this will be displayed as a notification to the user on the RBRs web page only. It will be up to the user to upgrade FW or not.
A factory reset maybe needed if problems are encountered after the FW update:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
I recommend configuring the default DHCP IP address (LAN) pool range to 192.168.1.100 thru .200 on the RBR if you have less than 100 devices online at one time.
This article applies to:
Let us know how it works for you...
  • FURRYe38 wrote:
    You might downgrade and report your findings.
    FWIW, upgrading to FW 4.6.11.1 solved some of the lag I was experiencing with 4.6.9.11.  Now, when I call up websites or put in a destination on Google Maps, I don’t see the several seconds of wait time as the progress bar crawls across the screen, nor do I see the “offline” travel time on Google Maps with an updated “live” travel time a few seconds later.
    • FURRYe38's avatar
      Good to hear.
      Enjoy. 📡
  • I didn't restore anything because it works fine with this firmware too, I only noticed this today. However I restarted everything and turned on in sequence RBR then the First RBS and finally the last RBS and the NETGEAR-GUEST network no longer sees itself as right because I have never activated it.
    • Theobuck's avatar
      Theobuck
      Apprentice
      Has anyone reported issues Firmware Version 4.6.11.1 for RBR750? I had some WI-FI and wired devices that had connection issues. I flashed the older version and restored the previous backup. Connectivity seems better.
      • FURRYe38's avatar
        Has a factory reset and setup from scratch been performed after applying last FW update?
  • I'm having trouble manaully updating my devices to the new firmware. The update system fails to upload the file to the browser before allowing to update the device. Screenshot attached.
    I've verified I'm using the proper file for my router and satellite "RBR750-V4.6.11.1_2.3.6-signed.chk" and "RBS750-V4.6.11.1-signed.chk"; however, after multiple attempts and restarting of devices I'm having no success. Anyone else experiencing this or have a potential solution?
    I'm hoping this firmware update solves some of the random drops and delays I've been experiencing since the last firmware update. Seems like many users have reported good results. My router sits about 3 feet from my main PC and I can often drop connection or see significant packet loss.
    • FURRYe38's avatar
      What browser are you using? Try MS Edge or Firefox.
      Clear out all browser caches before entering into the RBS or RBR web pages.
      I saw this same message however I had sent the wrong file to the wrong unit by accident. Be sure you update the RBS first with the RBS FW file, then the RBR lastly with the RBR FW file. Use the RBS web pages to send the FW file.
      Try a different PC and download the FW files again to the PC and unpack them. Be sure to NOT open the .chk files.
      • tucsontico's avatar
        tucsontico
        Virtuoso
        Have not updated to 4.6.11.1 yet. Asking if anyone experienced the Guest Network turning on by itself in Ver 4.6.9.11_2.3.5? That has been the only issue with the previous firmware for me. Have had over 60 days of uptime with minimal impacts on firmware 4.6.9.11. Don't want to update unless the latest fixes the Guest Network bug. Anyone seen this bug in 4.6.11.1?
  • Hello,
    Since weeks I have a bug with my orbi system and my Mac. Sometimes during 1-2 hours the connection is so poor between RBS and my computer, even drop the connection. With a Windows just next to me no problem.
    Has anyone experienced the same problem?
    Many thanks
    • anakin_ch's avatar
      anakin_ch
      Just to clarify I’ve just updated to this last version.
      • FURRYe38's avatar
        Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
        What Mac device do you have?
        What OS are you using on the Mac device?
        https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
        Set 20/40Mhz Coexistence to 40Mhz only.
        Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
        Turn off and unplug modem.
        Turn on computers and rest of network.
