- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - RBR750 / RBS750 Firmware Version 4.6.5.14 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RBR750 / RBS750 Firmware Version 4.6.5.14 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone tried to update to the latest v3 after rollback?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm running 3.2.18.1 firmware (with a pi-hole blocking the automatic firmware upgrade) since last night (about 24hrs in) and so far it's been pretty stable. I haven't seen any satellite connections drops, and speed on connected devices is definitely better than latest 4.x firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just sold my RBK753. For the price, it is the worst WiFi system I could have ever purchased.
Good luck with your purchase guys.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you don't have a way to block externally with a router or firewall device infront of the RBR, then you have to use the older FW version mentioned.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you think 3.2.18.1 will override the settings that I made through Telnet?
@FURRYe38 wrote:If you don't have a way to block externally with a router or firewall device infront of the RBR, then you have to use the older FW version mentioned.
@SergeL wrote:Does anyone tried to update to the latest v3 after rollback?
- Mark as New
- Bookmark
- Subscribe
- Permalink
5G WiFi speed on 3.2.10.10 is terrible!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya I think so. I remember someone mentioned upgrading to v1 after they had done the telnet config and it over wrote it. Unless you have a upstream router for firewall device in front, you'll have to use v10. If you can get another router in front of the RBR, then you could use v1 and block it.
Did you factory reset the system after downgrading and setting up from scratch?
How bad is the 5Ghz speed?
How are the 5Ghz channels configured?
Be sure you have CTS set for 2347 and WMM is enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did factory reset the system and pressed factory reset on the satellites.
Actually the link rate shows 866 mbps on 5G, I'll take back my statement, the MacBook that I used apparently got connected to the main router, instead of nearby satellite. Hence, it was on 2.4G, and it was slow. Toggling WiFi forced it to switch and now it's fast again.
So, I'll take it back 🙂
I'll stay on v3.2.10 for now. Will update in a week or so.
Thank you @FURRYe38 for great guidance
@FURRYe38 wrote:Ya I think so. I remember someone mentioned upgrading to v1 after they had done the telnet config and it over wrote it. Unless you have a upstream router for firewall device in front, you'll have to use v10. If you can get another router in front of the RBR, then you could use v1 and block it.
@SergeL wrote:Do you think 3.2.18.1 will override the settings that I made through Telnet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok thats good. Ya, gotta remember, some devices won't pick the nearest signal so you got to force them too.
Keep us posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Adding my experience with setting CTS
How to say prior to my current set up, with the latest firmware and a Ax turned off for 2.4
I did try to set the cars to 2347 and it pretty much shut down everything. Switched back to default setting 2341 2.4 and 2345 5.0 I believe and everything started again
Bet I did something wrong but with everything still returning to normal since Saturday I’m not gonna adjust anything else lol
Unless issues return
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well if your setting "cars to 2347" then this maybe an issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I downgraded my firmware to 3.2.18.1 and all was well. The auto update feature (which imho is not a "feature") put me right back onto 4.6 and the disconnects started occurring again. If it wasn't for the auto update and not being able to be in control of updating firmware on my own, I would have kept the unit. As it is, I returned it as that is a lot of money for a product which does not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
btw, i did now another test. as mentioned i have 1 rbr750 and 4rbs750. Before i had 1 satelite and behind them 2 others.
2x rbs---->rbs----->rbr. now i replaced it so that i have max 1 rbs behind another rbs (rbs----rbs----rbr)and since some hours it s working fine. Before all hours the one rbs in the middle was restarting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you think the middle RBS is the one with the problem? Does the problem seem to follow this one RBS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
i replaced this one with another but after a while the same problem occurs again. i also did a wired connection from rbr to this rbs but the it occurs again. since i have now 2 times rbs---rbs---rbr it s fine also the roundtrip over the last hours are much better.
before i changed it tried also to get log files out of it (via debug.htm) and i saw when the problem happend there wasn t only a connection lost the complete satellite was crashing (uptime)
@FURRYe38 wrote:So you think the middle RBS is the one with the problem? Does the problem seem to follow this one RBS?
@martin1982 wrote:btw, i did now another test. as mentioned i have 1 rbr750 and 4rbs750. Before i had 1 satelite and behind them 2 others.
- Mark as New
- Bookmark
- Subscribe
- Permalink
forget it, had the same issue again. may it s a problem with my alexas 🙂 as far as i now if there is multiroom audio they use igmp and would not be the first device which have problems with igmp. but i don t know. i hope there will be soon a new fw ...
@martin1982 wrote:i replaced this one with another but after a while the same problem occurs again. i also did a wired connection from rbr to this rbs but the it occurs again. since i have now 2 times rbs---rbs---rbr it s fine also the roundtrip over the last hours are much better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I rolled back to 3.2.18.1 . Been fairly stable. Better than the 4. Any reason you went that far back vs using the latest 3?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If users dont' have a upstream router or blocking device, that can't use v1, they have to go back to an early version of FW that has telnet enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm running a RBR750 wifi6 with 2 satellites. System is 2 months old and updated to 4.6.5.14 on Wed. 10/13. It was working flawlessly until this last update. Since doing so, devices would lose connectivity intermittently - only for 10-15 seconds - but this would occur for extended periods of time. 1-2 hours, then stabilize, then occur again. Makes working from home using Zoom a bit problematic as the connection is continuosly dropped.
I hard reset the entire system and rebooted from the modem --> router --> satellites. Didnt correct the issue. I reset to factory configuration. This also didn't correct the problem. Luckily, I purchased Pro support - the first time doing so could be considered a good investment.
The technician had me change 3 router settings using the Web interface:
1. Basic --> Wireless --> Changed 2.4Ghz channel to 11 from auto
2. Basic --> Wireless --> Changed 5.2Ghz channel to 44 from 48
Hit apply, router updated.
3. Advanced --> Setup --> WAN --> Changed MTU to 1472
I asked the technician on 2 separate occassions if doing so would have any performance impact and was told, "absolutely not". We shall see... but since making the changes, I haven't had any outages and the connection is stable. Speedtest indicates similar metrics to performance before the firmware update. I'll double check in the morning.
Hope it's helpful for others having the same problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@10DollarBill wrote:I'm running a RBR750 wifi6 with 2 satellites. System is 2 months old and updated to 4.6.5.14 on Wed. 10/13. It was working flawlessly until this last update. Since doing so, devices would lose connectivity intermittently - only for 10-15 seconds - but this would occur for extended periods of time. 1-2 hours, then stabilize, then occur again. Makes working from home using Zoom a bit problematic as the connection is continuosly dropped.
Sounds like you may still be within your return window. I'd take it back and get something else. This isn't the first time you are going to have issues. You will wake up to new firmware when they push it and it will be when you really need your system to work - not on your day off or a convenient time. Netgear has lost their minds and have pushed firmware over the past year or so that didn't help but caused issues for many. This past firmware has been an utter disaster.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wouldn't see a need to change the MTU unless your on a specific DSL modem service which those usually need. Most Cable and Fiber use 1500 MTU...
Will keep the wireless settings in mind...
