Reply
ORBI Hair Pinning
den452001
ORBI Hair Pinning
I have a server that unable to access external IP Addresses when connected to LAN.
For example External Ip Address: 108.111.111.222
Internal Ip Address. 192.168.1.100
When connected to the same network, Internal IP works, but external IP Won't work. However using the same device server machine , external ip works.
When i'm outside with other networks, External IP Works Flawlessly.
Device: ORBI RBR850 Server: Ubuntu 20.04
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Nnyan
Tutor
Re: ORBI Hair Pinning
So I'm not exactly sure if I understand your question, when you say hairpinning do you mean NAT loopback?   Your post doesn't seem to be describing a hairpin situation but that could be my misinterpretation.  Correct me if I'm wrong here:
108.111.111.222  WAN (ISP) port address on RBR850
192.168.1.100   Ubuntu Server
How exactly are you connecting everything in your two different scenarios?  Are you using VLANs ?
Xfinity Gigabit: Advanced Gateway XB7-T (Bridge Mode) > Orbi RBK753 > Palo Alto PA-220
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 212 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
