Reply
ORBI RBK850 keeps disconnecting with ISP after firmware update V4.6.3.16
LucGov
Star
ORBI RBK853 WIFI keeps disconnecting with ISP after firmware update V4.6.3.16
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 19
Guru
Re: ORBI RBK850 keeps disconnecting with ISP after firmware update V4.6.3.16
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router R7960P (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 19
Have exactly the same issue - keeps dropping the connection over and over again. My biggest regret, was that I paid a lot of money for updating from a perfect working RBK700 ORBI system to the ORBI850 wifi6 system. I will never recommend this.
Message 3 of 19
Guru
Message 4 of 19
LucGov
Star
Yes, I did a power up several times of my ORBI 853.  Also power down/up of the provider modem/bridge.
II even did a roll-back of the software to version V4.6.3.9, but that doens't make a change.
The system worked perfect before this FW upgrade.
Any news from the Netgear helpdesk about a fix ?
Message 5 of 19
Guru
What happens if you leave the RBR and RBS turned OFF over night then back on first thing in the morning?
Were seeing others post that leaving the Orbi units unplugged for several hours is helping to correct problems seen.
https://community.netgear.com/t5/Orbi-WiFi-6/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2144840/hi...
No time frame on when fw new is forth coming. NG doesn't post this.
Message 6 of 19
LucGov
Star
Hi, doesn't make a difference. Made a roll-back to V3, but in moments ORBI was re-loading the lastest FW V4. I guess every owner of a ORBI 850 should be in trouble now ?
Message 7 of 19
Guru
Have to roll back to v10 then do this to stop the updates from happening:
https://community.netgear.com/t5/Orbi-WiFi-6/RBK750-Series-Firmware-Update-v4-6-3-7/m-p/2131307#M186...
Message 8 of 19
bosbosbos
I have the same issue with orbi RBK850
The master disconnect from the internet usually one time every day.
It started a few days ago. the unit is on V4.6.3.16
Disconnection the network cable from the master to the ISP modem and reconnecting it helps, but the day after it is down again.
Message 9 of 19
Guru
Message 10 of 19
bosbosbos
This is the CBN CV8560E
regards
Bosbosbos
Message 11 of 19
Guru
What mode is the modem working in? Bridge or Router? Seems that maybe this modem/ONT has a built in router possibly.
Message 12 of 19
Adam87
Initiate
Same problem here, my Orbi RBK853 keeps dropping wifi signal randomly everyday, I paid $1200 for this wifi mesh system and it's not working properly. I don't want to regret not going with google but this needs to be FIXED ASAP.
Message 13 of 19
Guru
Try this?
https://community.netgear.com/t5/Orbi/Orbi-RBK852-4-6-3-16-broken-Solved/m-p/2174967/highlight/true#...
Message 14 of 19
Guru
Have you tried it yet? The OP seems to feel it works better than v4.6.3.16.
Message 15 of 19
Adam87
Initiate
I changed the router to AP mode and that helped with the frequent disconnect, but issues with AP mode has risen! For example nothing connects to the satellites, they alway show 0 devices connected...
Message 16 of 19
Guru
@LucGov @Adam87
Try this?
Message 17 of 19
Guru
I recommend you start a NEW post and give us some details and start posting in this new post thread.
You can start at the beginning if you want to and we'll go from there.
@Yashur21 wrote:
Try this?
So many questions.  I getting lost
how do keep up?
Message 18 of 19
Guru
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 1389 views
  • 5 kudos
  • 5 in conversation
Announcements
Orbi WiFi 6E
