Reply
ORBI RBS850 Satellite restarts several times a day
_tus_
Tutor
Hi,
I'm using a RBK853 kit, upgraded to V3.2.16.6_1.4.4 version for all parts.
RBR850 is configured in AP mode, both RBS850 satellites and RBR850 router are in DHCP mode.
One RBS850 satellite of the kit is restarting mutiple time a day according to its system uptime.
The router RBR850 and the second RBS850 are also restarting autonomously from time to time but not as often as the other one.
Up to now I was not able to catch the RBS850 restart in its debug log and I was wondering how I'm supposed to proceed to get one:
When I retrieve the capture, it starts at the restart and lacks the reset itself.
Could I see the restart in the RBR850 logs to investigate what is going on?
For the technical settings on RBR850:
Region : Europe
No 20/40 MHz coexistence
WMM activated on both 2.4GHz and 5GHz
RTS 2347 on both 2.4GHz and 5GHz
Automatic preamble for 2.4GHz and short one 5GHz
Guillaume
Message 1 of 16
Accepted Solutions
_tus_
Tutor
Re: ORBI RBS850 Satellite restarts several times a day
Hello
I forgot to post a follow-up.
After redoing the same test with the netgear support, RMA was granted and the faulty RBS was replaced a dozen of days ago.
So far, it works like a charm.
Many thanks to @FURRYe38
Message 15 of 16
All Replies
Guru
Are you using a Dynamic or Static IP address configuration on the RBR in AP mode?
Has a power off for 1 minute then back on been performed since last update?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 16
_tus_
Tutor
Hi,
Router is my ISP one : Sagem Livebox 3 Pro for Orange France ISP.
RBR850 gets its fixed IP from DHCP (mandatory for Livebox DNS activation), same for the 2 satellites.
No more than a dozen of Wifi network nearby.
None with more than -70dBm SNR under wifi analyzer when Orbi's one are over -44dBM (I'm in a separate House).
Between 2 restarts, wireless / wired connection through the RBS850 is reliable which does not seems to indicate an interference issue.
The RBS850 which restarts often has been power-off for more than a days without change in its behavior.
The RBR850 and the second RBS850 were not powered-off more than the time they need to restart.
Message 3 of 16
Guru
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
I presume any wiif radios on the ISP modem are turned OFF fully?
Message 4 of 16
_tus_
Tutor
Manually set to Chanel 11 for 2.4GHz. ISP router has wifi disabled.
So far no restart observed on the satellites (it also spent the whole night unplugged).
Let see if this solves my concern.
In the meantime, any clue on how fixing the 2.4GHz channel could have a influence on the unexpected restart of the system?
Guillaume
Message 5 of 16
Guru
Possible nieghboring wifi...
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try swapping RBS locations to see if problem follows.
Keep an eye on it...
Message 6 of 16
_tus_
Tutor
3 story house for about 1600 Sq Ft.
- RBS850 on ground floor (roughly 40 feets distance with RBR850 througt concrete)
- RBR850 on first floor, wired to Livebox router
- RBS850 on second floor (close to 20 feets distance with RBR850 througt wood floor) <= This is the one restarting autonomously
I was aware of the 30 feets recommendation but I was not convince it could be the cause of reboot of the system.
I will try to find a better location for the second satellite and keep an eye on it.
At least since I fixed the 11 channel instead of letting it automatic, I did not see any reboot.
Message 7 of 16
Guru
Ya if 20 feet is distance between the RBR anr 2nd RBS, this is too close...
Message 8 of 16
_tus_
Tutor
Hi netgear community,
I'm undigging a long lasting thread...
I continued investigation on my side since the RBS852 was still resetting several times a day.
For the record, I got one RBS852 Satelitte (called Office) which reset spontanously several times a day and I got one RBS852 Satelitte (called Multimedia) which works like a charge.
Both satelittes came from the same RBK853 kit.
I finally got the oportunity to exchange both satellite places:
Bureau is now used to deliver content to the TV / Game console / Chromecast
Multimedia is now used to provide fast access to our home office (couple of computers wired and/or wireless; printer, couple of phones...)
As @FURRYe38  can guess, Bureau is still resetting when Multimedia works like a charm.
Since I carefully used the same location during the exchange, I can conclude that we are not in front of interference or any external environnement issue and I suspect now an HW problem with the satellite called office...
What are the next step to progress? Is there any debug available to track why the satellite is resetting?
Message 9 of 16
Guru
Sounds like the one RBS call Office could be faulty. Swap RBS locations to see if the problem follows. If it does, I presume the one RBS needs to be replaced. Something to contact NG support about and see if there are any options.
@Blanca_O
Message 10 of 16
_tus_
Tutor
OK, I will swap the RBS location again to confirm it is linked to "office" RBS850 later today and I keep your posted.
Guillaume
Message 11 of 16
Guru
Smiley Wink
Message 12 of 16
_tus_
Tutor
Ok, RBS switched back to there original position:
RBS Multimedia is working as like charm for a whole week
Firmware Version: V3.2.16.22_1.4.9
CPU Load: 16.67%
Memory Usage(Used/Total): 408 MB/867 MB
System Uptime: 7 days 19:26:22
Hop Count: 1
When RBS Office is continously resetting.
@Blanca_OAny hints on how to trig the support to discuss any other test before starting RMA actions?
Message 13 of 16
Guru
You might send them a direct PM as well.
Good Luck.
Message 14 of 16
_tus_
Tutor
Hello
Message 15 of 16
Guru
Glad you got a replacement.
Enjoy. Smiley Wink
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 843 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
