Orbi WiFi 7 RBE973
Reply
Only 1 entry shows in log
donawalt
Virtuoso
This is an odd quesiton...my RBR850 router and satellites installation is about a week old, running well...but one odd thing I noticed, I only ever have 1 entry in the log file that shows. Now, the only entry I have seen is issuing a DHCP address; I don't see any reason I should have had any other entries. I know today for example, I had three different DHCP entries, but when I looked at them, only the latest showed - what I mean is at 11 AM I saw a DHCP log entry for 10:30 AM; Yet at 12:30 I saw a DHCP log message from 12:00 PM ONLY; then at 1:30 PM I saw a DHCP log message for 1 PM ONLY. What happened to the other messages?
Note I HAVE NOT cleared the log file (that gives a message too.) I have looked at the log on Safari/Mac, Chrome/Mac, and Edge/Windows, with the same behavior.
Why do you think there is only one message that shows?
Message 1 of 22
Chuck_M
Mentor
Re: Only 1 entry shows in log
Logs are all dorked in my Orbi... I never have more than 6 or 7.  It is a known issue.
Message 2 of 22
donawalt
Virtuoso
I have watched this some more - when I first reboot the router and go to the log, I see a number of entries - mostly the DHCP address issuing, but enough entries that it scrolls. If I come back in 20 minutes or so and log in and check the Logs again, there is only 1 entry. It sure seems like some sort of router bug.
Message 3 of 22
Guru
Please let NG support know about this if you haven't already.
@Blanca_O
@Christian_R
Message 4 of 22
donawalt
Virtuoso
Sure- I see the two names, what is the best way to tell them?
Message 5 of 22
Guru
Send them a private message.
Message 6 of 22
donawalt
Virtuoso
@FURRYe38 done - sent a message to oth describing the problem.
Message 7 of 22
Guru
Smiley Wink
Message 8 of 22
Guru
Im seeing several lines of logging on my system:
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:18:33
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:18:03
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:17:28
[DHCP IP: (192.168.0.106)] to MAC address, Thursday, Aug 20,2020 13:17:14
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:17:03
[DHCP IP: (192.168.0.106)] to MAC address, Thursday, Aug 20,2020 13:16:03
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:15:58
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:15:37
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:15:27
[Admin login] from source 192.168.0.106, Thursday, Aug 20,2020 13:14:42
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:14:32
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:14:24
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:14:13
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:13:08
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:12:44
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:12:22
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:11:39
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:11:21
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:11:18
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:10:16
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:09:56
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:09:30
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:08:50
[Admin login] from source 192.168.0.106, Thursday, Aug 20,2020 13:08:42
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:08:30
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:08:26
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:07:25
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:07:01
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:06:35
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:05:55
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:05:33
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:05:31
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:04:27
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:04:08
[DHCP IP: (192.168.0.117)] to MAC address, Thursday, Aug 20,2020 13:03:57
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:03:03
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:03:03
[DHCP IP: (192.168.0.106)] to MAC address, Thursday, Aug 20,2020 13:02:44
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:02:42
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:01:59
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:01:37
[DHCP IP: (192.168.0.106)] to MAC address, Thursday, Aug 20,2020 13:01:32
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:01:19
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 13:00:14
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 13:00:10
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:59:52
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:59:06
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:58:47
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:58:23
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:57:17
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:56:54
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:56:47
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:55:48
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:55:44
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:55:28
[DHCP IP: (192.168.0.107)] to MAC address, Thursday, Aug 20,2020 12:54:40
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:54:23
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:53:59
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:53:27
[Admin login] from source 192.168.0.106, Thursday, Aug 20,2020 12:53:19
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:52:53
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:52:34
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:52:23
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:51:29
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:51:09
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:50:32
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:50:04
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:49:44
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:49:29
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:48:39
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:48:15
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:47:41
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:47:10
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:46:52
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:46:37
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:45:47
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:45:24
[DHCP IP: (192.168.0.117)] to MAC address, Thursday, Aug 20,2020 12:44:54
[DHCP IP: (192.168.0.110)] to MAC address, Thursday, Aug 20,2020 12:44:40
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:44:34
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:44:19
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:43:58
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:43:31
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:42:53
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:42:32
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:41:31
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:41:27
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:41:08
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:40:28
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:40:03
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:39:44
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:38:39
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:38:15
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:37:51
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:37:09
[DHCP IP: (192.168.0.108)] to MAC address, Thursday, Aug 20,2020 12:37:02
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:36:48
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:36:48
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:35:42
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:35:23
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:34:51
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:34:18
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:33:56
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:33:47
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:32:51
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:32:26
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:31:41
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:31:20
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:31:01
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:30:38
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:29:56
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:29:30
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:28:37
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:28:25
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:28:06
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:27:34
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:27:01
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:26:35
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:25:42
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:25:30
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:25:05
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:24:39
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:24:00
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:23:38
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:22:32
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:22:23
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:22:13
[DHCP IP: (192.168.0.117)] to MAC address, Thursday, Aug 20,2020 12:21:24
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:21:20
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:21:08
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:20:47
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:19:42
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:19:21
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:19:11
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:18:16
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:18:07
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:17:51
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:16:45
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:16:21
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:16:16
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:16:15
[DHCP IP: (192.168.0.106)] to MAC address, Thursday, Aug 20,2020 12:15:49
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:15:16
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:15:12
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:14:55
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:14:51
[DHCP IP: (192.168.0.127)] to MAC address, Thursday, Aug 20,2020 12:14:23
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:13:50
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:13:24
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:13:07
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:12:47
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:12:37
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:12:22
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:12:19
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:11:57
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:11:44
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:10:51
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:10:29
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:09:24
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:09:06
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:09:03
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:08:03
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:07:58
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:07:33
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:07:08
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:06:45
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:06:28
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:06:09
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:05:50
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:05:04
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:04:47
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:04:42
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:04:37
[DHCP IP: (192.168.0.105)] to MAC address, Thursday, Aug 20,2020 12:04:18
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:03:37
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:03:18
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:02:51
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:02:13
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:01:49
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 12:01:47
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:00:44
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 12:00:21
[UPnP set event: DeletePortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 11:59:40
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 11:59:16
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 11:58:56
[UPnP set event: AddPortMapping] from source 192.168.0.115, Thursday, Aug 20,2020 11:58:37
[UPnP set event: AddPortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 11:57:51
[UPnP set event: DeletePortMapping] from source 192.168.0.120, Thursday, Aug 20,2020 11:57:26
[DHCP IP: (192.168.0.106)] to MAC address, Thursday, Aug 20,2020 11:56:26
I had to delete part of the log capture for forum posting not to exceed 20000 characters. Smiley Frustrated
All logging boxes are checked aceept for the 1st two and the very last one.
v6 FW loaded.
I see the time frame seems to be only about two hours or so.
Message 9 of 22
donawalt
Virtuoso
Interesting. I heard back from @Blanca_O  and she said they had heard of the problem I reported here from others. Something different in configuration may cause it?
Message 10 of 22
Guru
Anything is possible. Hopefully they can figure it out.
Mines connected to a CM series modem only cable modem. SparkLight ISP.
RBR is in router mode. RBS both ethernet connected behind RBR via GB switches.
Using a 192.168.0.100 to .150 Default DHCP IP address pool.
Auto DNS detect.
CTS 64
20/40Mhz.
No Armor enabled.
Opera Browser.
Message 11 of 22
donawalt
Virtuoso
Here is my config:
Comcast ISP -> CM1200 -> Orbi RBR8500. 2 RBS8500's. No other network hardware - no switches, DHCP servers, etc.
RBR is in router mode (But get this - for the first time, I brought up orbilogin.net, logged in, and as I went to Advanced to see Router/AP Mode, it's grayed out! Have oyu ever seen that?)
All defaults for DHCP address pool, Router acts as DHCP.
CTS 2347 on 2.4 and 5GHz (0 collisions still!)
20/40 MHz
No Armor, no Guest network, UPnP on, IPv6 enabled, no bridges, VPNs, static routes, port forwarding/triggering.
Remote management turned off.
Message 12 of 22
Guru
Well maybe you have the wrong forum for your RBR8500 and RBS8500. LOL. Kidding.
Haven't see any probems with Router or AP mode:
Have you factory reset your RBR since last update?
What browser are you using for the RBRs web page? I'm use Opera Next.
I don't have IPv6 enabled since my ISP doesn't support it natively.
I have about 30 devices online, wireless phones, wired PCs, wired NAS, 3 wired printers, 4 wireless cameras, DISH Hopper system and 2 wired Joeys and 3 xbox consoles.
Message 13 of 22
donawalt
Virtuoso
@FURRYe38 I think I have 15 devices online - printers, laptops, iPad, iPhones, hubs, Apple TVs, TVs.
I have not done a factory reset since the last update. The documentation didn't say I had to, do I? That seems like a lot of work starting over?
I tried Safari and Chrome - grayed out. Seems like some new little thing pops up every other day lol. I have seen your graphic a lot, just stopped being available now. Maybe because I went to LAG today? I bet that is it!
Message 14 of 22
Guru
Well the LAG on the CM1200 got new FW from those ISPs that pushed that is supposed to fix LAG slow down.
Yes if you enabled LAG on the RBR, then maybe AP mode is disabled from use untill LAG is disabled on the RBR. I think I remember that now.
I bet AP mode will be availalble when LAG is disabled. Smiley Wink
Message 15 of 22
donawalt
Virtuoso
Me too! I know I saw that screen a lot before today. No worries! I would rather have the speed and I have no reason to make it an AP as I have no other router lol.
Message 16 of 22
Guru
Ya your fine.
Thought you might reset the RBR at some point to check for logs, though I didn't reset mine after applying the new v6 FW. I downloaded mine and applied them manually with a wired PC. Wasn't your auto updated?
Message 17 of 22
donawalt
Virtuoso
Yes I just auto updated firmware, I have never done a manual update of firmware.
Message 18 of 22
Guru
Maybe one issue causing logs to not display all info. Someting you might try re-loading v6 FW and factory reset to see if changes anything.
Message 19 of 22
KMDonlon
Luminary
The most recent firmware seemed to fix log entries for me, logs fill up like normal now for since the update. All fixed on my end (so far)
Message 20 of 22
Guru
Thanks for letting us know. Has been an odd problem.
Message 21 of 22
Chuck_M
Mentor
My logs are still broken.  These are only entries after days of uptime:
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:16:40
[Admin login] from source 192.168.1.27, Friday, Aug 21,2020 22:16:40
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:16:05
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:15:30
[DHCP IP: (192.168.1.26)] to MAC address CC:DD:A2:03:FF:46, Friday, Aug 21,2020 22:14:58
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:14:55
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:14:20
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:13:45
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:13:10
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:12:35
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:12:00
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:11:25
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:10:50
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:10:15
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:09:40
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:09:05
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:08:30
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:07:55
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:07:20
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:06:45
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:06:10
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:05:35
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:05:00
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:04:25
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:03:50
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:03:15
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:02:40
Message 22 of 22
Top Contributors
Discussion stats
  • 21 replies
  • 1955 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
