Orbi WiFi 7 RBE973
Reply
Orbi 6 RBR850 SSID issue (Please Help!)
MinionTA
I purchased an Orbi RBR850 in March of this year.  It was amazing.
In June it started acting very sketchy and some random wifi devices (alexa/cameras) stoped working. The guest wifi which is only used for a few items worked fine.  I tried rebooting/powering down the Orbi and cable modem but it just wasnt cooperating.  I eventually did a factory reset on the Orbi and gave it a new SSID and readded everything to the network and it was again amazing.
This month it started doing the exact same thing.  The guest wifi yet again works fine.  I did a factory reset and changed the SSID and it yet again starts working great.  When I change the wifi to the old SSID it stops working.
Why would the guest wifi work and if I create a new SSID it works yet after a few months on an SSID devices would randomly stop working? I have around 80 devices on the wifi.
Having to readd 80 items to a new SSID every couple months is not an option I am good with. Please help.
Message 1 of 4
Guru
Re: Orbi 6 RBR850 SSID issue (Please Help!)
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter, IPv6 and
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
Do you have devices connected to Guest Network all the time?
Message 2 of 4
MinionTA
Current Firmware = v4.6.3.16
Netgear CM2050V Modem
3200 Sq ft - 2 level home
Satilite is on floor 1, Router is on Floor 2.  I would estimate roughty 25-30 ft apart with a floor between.
It is on auto for channel.  I can certainly try a channel suggested.
I have 2 neighbors but they do not have wifi.  I have a neibor across the street that does have wifi and appears weak in my home.
Traffic, Circle, Armor, and Ip6 are disabled already.
I do not understand the coexistence/CTS part but I can certainly change that if it could help.
I do have devices connected to guest at all times.  I am guessing it is usually 5-9 devices on guest and the remaining 60+ were on the main SSID.
The most recent factory reset was done a few days ago.  I do not know if a firmware update has been completed since the factory reset before that.
Message 3 of 4
Guru
Satilite is on floor 1, Router is on Floor 2.  I would estimate roughty 25-30 ft apart with a floor between. I would try moving the RBS a bit farther out.
I do not understand the coexistence/CTS part but I can certainly change that if it could help. Please try the sugggestions.
I do have devices connected to guest at all times.  I am guessing it is usually 5-9 devices on guest and the remaining 60+ were on the main SSID. Are you 60+ devices spread out connected across the RBR and the RBS or are they all connected at the RBR?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 527 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
