- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi 840 Drops Wifi Everyday at 10:30am
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have an Orbi 840 system which we really like, except for one annoying issue. Everyday around 10:30am, it kicks every device off of the wifi for a few minutes. Any devices that are hardlined to the orbi lan ports are fine. It's just the devices connected via wifi. I am running firmware 3.18.
Is this a known issue, or is there a way to at least force this drop to happen during the middle of the night?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi 840 Drops Wifi Everyday at 10:30am
Does the front LED on the RBR or RBS turn on WHITE, PINK or BLUE when this happens?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Traffic Meter and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
