Orbi WiFi 7 RBE973
Reply
Orbi AX4200 Router RBR750 mesh system preventing file uploads to confluence
KateD
Follower
I recently purchased an orbi tri-band mesh wifi 6 system. The model is AX4200 with one router (RBR750) and one satellite (RBS750). The Armor security comes free for a few months. Armor free trial has just expired. I'm not sure if this is coincidental however I noticed I cannot upload files to some confluence spaces any more. There appears to be a security policy kicking in and i cannot find any information online why this is happening. I'm hoping this isn't something that is locked into the product and cannot be changed. Has anyonre experienced this issue with orbi's security? It is challenging to get support now that the first 3 months are passed. Thanks
Message 1 of 3
Guru
Re: Orbi AX4200 Router RBR750 mesh system preventing file uploads to confluence
You might try in the orbi forum.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
One of the things I'd try would be a simple factory reset and reinstall.
Message 2 of 3
Guru
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 578 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
