Orbi WiFi 7 RBE973
Reply
Orbi AX6000
SRTrybus
Tutor
Orbi AX6000
Can you use an AX4200 as an additonal sattelite on an AX6000 system with router + 2 satelites? The AX6000 individual satelites are not avaialble and I need another sattelite for coverage.
Message 1 of 7
Guru
Re: Orbi AX6000
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Yes.
Message 2 of 7
SRTrybus
Tutor
Re: Orbi AX6000
Over 8000 sq ft on 4 levels so thinking I need router on 1 and satelites on the others
Message 3 of 7
Guru
Re: Orbi AX6000
Ok.
Message 4 of 7
SRTrybus
Tutor
Re: Orbi AX6000
so back to my question, does anyone know if you can use a 4200 sattelite in connection with a system that has a 600 router and two 6000 sattelties ?
Message 5 of 7
SRTrybus
Tutor
Re: Orbi AX6000
edit - 6000 router
Message 6 of 7
Guru
Re: Orbi AX6000
Yes you can.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1249 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
