- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi AX6000
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Orbi AX6000
Hi All,
Quick question: has anyone successfully connected the Orbi AX6000 to a BT Smart hub 2?
Mine refuses to connect to the internet
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi AX6000
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure to check cabling in between as well. CAT6 is recommended.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK853 (Router Mode), Wired Backhaul and RBK752 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi AX6000
Sounds technical but I'll give it a go! Thanks for taking the time to reply.
Matthew
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi AX6000
Good Luck.
