Orbi WiFi 7 RBE973
Reply
Orbi Mesh Router
jscrna
Follower
Orbi Mesh Router
Orbi Mesh Wi-Fi 6
I just ordered an Orbi RBK752 to replace a Nigthawk R7000. When I set up the Orbi, I am going to give it the same User Name and Password as the Nighthowk. Will the devices connected to the Nighthawk, automatically connect to the Orbi? I would hate to have to reestablish the connected devices.
Thanks, Jeffrey
Message 1 of 5
Accepted Solutions
CrimpOn
Guru
Re: Orbi Mesh Router
@jscrna wrote:
Orbi Mesh Wi-Fi 6
Thanks, Jeffrey
Yes, they will.
Message 2 of 5
All Replies
CrimpOn
Guru
@jscrna wrote:
Orbi Mesh Wi-Fi 6
Thanks, Jeffrey
Yes, they will.
Message 2 of 5
Sreyleab
Initiate
Message 3 of 5
PaulHalstead
I will be getting a direct connect fiber (CenturyLink). I want internet only-no cable. It looks like I don't need a CenturyLink modem at all. The "Orbi Whole Home Tri-band Mesh WiF 6 System (RBK852) would be enough to get WiFi from the active fiber connection. Is this correct???
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 4 of 5
Guru
You need to ask your ISP if any kind of modem or gateway router they have may be required first and if not, what is needed to use on the RBR as the internet interface for the ISP service.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 959 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
