Reply
Orbi RBK 750 Static Route to Modem UI, Starlink
akoMN
I connected an RBK750 router to my Starlink dish directly, which means I replaced the Starlink router.
The Starlink dish has an internal IP address 192.168.100.1 with statistical data that I want to access.
RBK750 LAN address is 10.0.0.1
I tried to set up a static route:
Destination IP Address: 192.168.100.1
IP Subnet Mask: 255.255.255.255
Gateway IP Address: 10.0.0.1
Metric: 2
Unfortunately, it doesn´t work. What's wrong?
Message 1 of 21
Guru
Re: Orbi RBK 750 Static Route to Modem UI, Starlink
Ask your ISP if there modem/router is required for use wtih there hardware. Some ISP may require there HW to be used.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 21
akoMN
The ISP is Starlink and the modem is their dish. I already skipped the Starlink router and connected the RBK750 directly. Works all fine. I only want to have a static route from my network to the modem's statistic page.
I found out that it works when I use the to public IP address assigned by the ISP as Gateway IP address instead of the internal router address 10.0.0.1.
On other routers, I would try 0.0.0.0 as the gateway, but the RBK750 refuses to use this address ("invalid gateway address").
Message 3 of 21
akoMN
Unfortunately, it works only until a new public IP iss assigned by the ISP. So this is not a solution.
Message 4 of 21
Guru
I'd ask the ISP what there IP address of the modem is. Most cable modems use 192.168.100.1 which passes thru most routers to connected PCs. Something to ask your ISP about.
Message 5 of 21
akoMN
The modem IP address is indeed 192.168.100.1, but it doesn't pass thru the RBK750 router. Still looking for a reliable solution to add a static route for this. Seems to be a lacking feature of an otherwise great product.
Message 6 of 21
Guru
I should. My CM1200 uses same addresss and I get thru my 850....
What browser are you using?
Is there a model# of this mome or is that something specific to this ISP?
Message 7 of 21
akoMN
I tried Chrome, Safari, Opera, and Firefox.
The "modem" is a Starlink satellite dish. The technology is great, It comes with everything and is plug&play. Only the WIFI router is a little weak and the only thing that can be configured is the SSID. So I did what many users do, I bought a mesh WIFI system (Orbi WIFI 6) and connected the router directly to the "modem". Works well, except that I cannot access the status page on 192.168.100.1.
Other Starlink users solved this by setting up a static route, but this is not working with the Orbi router.
Message 8 of 21
TTFD753
I have the same setup. What is interesting is the Starlink app/stats work until the Orbi grabs an internet connection. Once that gateway is established, the Starlink app and stats no longer work and the app loses connection to Dishy.  I can replicate this by power cycling both Dishy and Orbi at the same time. Once phone receives wireless connection, the Starlink app connects to Dishy.
My static route info:
Static Route 192.168.100.0
Subnet 255.255.255.0
Gateway 10.4.0.1
Metric 2
Message 9 of 21
TTFD753
Also I have tried using different gateway addresses in that static route setup and end up with the same result.
I have tried:
1.1.1.1 (since it will not let you use 0.0.0.0)
192.168.100.1
Message 10 of 21
Macrich
Tutor
I am also trying to hook up my Orbi to Starlink to access the stats on the app. Where do I find the public IP address assigned by Starlink to use as the Gateway IP address? Is it Basic/Internet/Internet IP address/Gateway IP Address ?
Message 11 of 21
TTFD753
You use the one listed in Basic/Internet/Internet IP Address/IP Address. Do not use the one listed in the Gateway IP Address field as that one will not work.
Message 12 of 21
Macrich
Tutor
Thanks I'll give it a go. I assume that if the dish or Starlink router reboots I come back there and enter the new address.
Message 13 of 21
TTFD753
Yes you are correct. Every time Dishy reboots it issues a new public IP and you will have to update the static route gateway with this new IP.
Message 14 of 21
Nyquist91
I have exactly the same setup with Starlink. I can set the static route to use the assigned IP and stats work, but once that IP changes it stops working.
Other routers appear to support 0.0.0.0 - it looks like we are out of luck with the Orbi.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 15 of 21
Guru
Ask the ISP to give you a static IP address on the WAN side?
Message 16 of 21
akoMN
Starlink doesn't offer static IP at this time.
Message 17 of 21
jescott3
Guide
Yes, it is a workable solution. The main problem is that any time the Starlink dish is reset or unplugged from power, the IP address changes. All that is needed to fix this is to login to your Orbi router then find and replace the old IP address with the current one. Here's a step by step method to do that works perfectly using my Orbi RBR50:
orbilogin > Advanced tab > ADVANCED Home > Internet Port (box in right panel) > IP Address (copy it) > Advanced Setup > Static Routes > Destination box (enter 192.168.100.0) > Gateway box (enter copied IP Address from Internet Port box in earlier step) > Click Save and you're done.
Message 18 of 21
Guru
Thanks for posting this. Hope this is helpful for StartLink users.
Message 19 of 21
akoMN
For sure this works, but it is not really comfortable to do it every time the public IP changes.
I solved it by installing an ethernet only router (Ubiquiti) between the Starlink modem and the RBR750. The RBR750 is working in AP mode now.
Message 20 of 21
Nyquist91
Agreed, this is not a good solution.
Message 21 of 21
Top Contributors
Discussion stats
  • 20 replies
  • 2280 views
  • 1 kudo
  • 6 in conversation
Announcements
Orbi WiFi 6E
