× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
Orbi RBK352: (DNS?) Issues after restart
Mytherin
Tutor
A few days ago I got my Orbi RBK352. I have set it up in AP mode. The Orbi is directly connected using an ethernet cable to my primary modem/router. Everything works well and the internet/connectivity is great, but somehow after restarting the Orbi I run into very odd internet issues:
  • Certain websites will load (e.g. google) but others do not (e.g. github).
  • While google works in the browser, pinging google does not (typing `ping www.google.com` in the terminal leads to a time-out)
  • I am not able to connect to `orbilogin.com` on my laptop, only on my phone. My phone does have the same issues loading various web pages though.
  • The pages that can be loaded and cannot be loaded are consistent (e.g. google is always available, github is never available).
  • When this happens, if I connect to the wifi on my main router none of these issues are there and the internet works as expected.
What fixes the problem is switching the Orbi from AP Mode back to Router Mode, and then switching it back to AP Mode. This fixes all of the issues, at least until the next restart, and the internet works great again.
Does anyone have any idea what could cause these issues and how I could resolve them permanently without having to do this switch every time the Orbi is restarted?
The Orbi is on the latest firmware version (V4.4.0.10_2.10.63).
My laptop is a Macbook, and my phone is an iPhone. I tested different browsers (safari, chrome) and the issues were present in every browser. I also tried resetting caches of the browser and that did not fix the problem either.
Message 1 of 5
Accepted Solutions
Guru
Re: Orbi RBK352: (DNS?) Issues after restart
What DNS is being used on the host router? ISP or custom?
Did you set up the RBR for a Dynamic or Static IP address for AP mode? Static IP address is recommended.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 5
All Replies
Guru
Message 2 of 5
CrimpOn
Sage
How often does the router restart?  My router has gone six months without restarting.  I have it on a small UPS to prevent 'power blips' from triggering a restart and only a 6 hour power outage was long enough to drain the UPS and force a restart.
Can you please clarify one tiny detail: the iPhone is obviously connected to the Orbi over WiFi.  How is the Macbook connected? (WiFi or ethernet?)  The reason I ask is that orbilogin.com, orbilogin.net, routerlogin.com (and several others) are not real internet URL's.  They are intercepted by the Orbi which says, "oh, that's ME."
Many users would designate fixed IP addresses for the Orbi router and satellites in the primary router setup tables so that (a) they will always be at the same IP address, and (b) so that a browser can find them using the IP address rather than the phantom URL.
I love my Orbi.
Message 3 of 5
Mytherin
Tutor
I was using a dynamic IP address, switching to the static IP address seems to have solved the problem! Thanks.
In general very rarely, but I was doing some work that required me to turn off the electricity a number of times, hence my annoyance at the problem 🙂
Message 4 of 5
Guru
Enjoy.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 355 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
