Reply
Orbi RBK50 delay in connecting to internet
Brad21
Orbi Mesh RBK50 with satellite (purchased 2018) and Surfboard SB6141 DOCSIS 3.0 cable modem (purchased 2013) connected to Comcast.  Comcast says signal to modem meets specs.  Desktop connected via ethernet cable and wifi connects tablets, laptops and phones.  When each is turned off (or desktop goes to sleep) there can be a long delay (minutes+) before device connects to internet.  Intermittently happens, but frequent enough to be a big problem.  Where do I start to replace....modem or Orbi?
Thank you
Message 1 of 4
Guru
Re: Orbi RBK50 delay in connecting to internet
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
The cable between the modem and RBR of good quality? CAT6 is recommended.
Has Traffic Meter been enabled on the RBR? Disable it if it is.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 4
Brad21
Thank you for the suggestions to try.  Since they are numerous, it will take me some time to try them.  I really appreciate your time to respond.  Thank you
Message 3 of 4
Guru
Let us know if you need any more help...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 174 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
