Reply
Orbi RBK750 issue with ps5 and Sky q
Manny_B
Tutor
I have a 1gb internet service from virgin media and have put the Virgin media router into modem mode and the Orbi RBK753 into router mode on the ground floor. I have 2 satellites not too far - one on the ground floor and the other upstairs.
I have sky q where the main box is connected via Ethernet (2ghz field is switched off and using 40mhz channel 36)to the main router and the sky mini boxes are connected via WiFi (with a sky booster in the middle between the main box and mini boxes) which works well. No connection issues whatsoever thankfully and fantastic speeds through the house.
Can use devices like tablets and phone while using one ps5/ sky mini boxes simultaneously however the problems starts when myself and brother start using our ps5s. Not only do the ps5s lag while playing online but sky q mini boxes stop working altogether. When one ps5 is in use then all is well.
The ps5s are connected wireless to a satellite nearby (a satellite where it is not being hogged by other devices) using 5ghz and cannot be wired. The sky q mini box which I know they use 5ghz also cannot be wired.
Any helpful suggestions would be much appreciated as even with two ps5s in use, the whole network speed is greatly reduced.
Thank you.
Message 1 of 5
Accepted Solutions
Guru
Re: Orbi RBK750 issue with ps5 and Sky q
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try turning OFF 1 of the RBS.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 or 48 channel on 5Ghz.
Armor, Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347 and Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Can you wire both PS5s to the RBS?
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 3 of 5
All Replies
Guru
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Testing
Message 2 of 5
Guru
Testing
Message 3 of 5
Manny_B
Tutor
Apologies for the delay in responding but I have now followed your suggestions including wiring one console directly to a satellite and amending the settings in the orbi.
Seems all stable now!-thank you
Message 4 of 5
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Enjoy.
Testing
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 931 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
