- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK752 - Devices will not connect to satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a new Orbi RBK752 system with the router on the main level in my office and the satellite in my son's room upstairs. He has a computer and X-Box hard wired in to the satellite which seem to work fine, but nothing seems to be able to connect to the satellite via WiFi. The router has 20+ devices connected, but the satellite has none. His Roku TV nor his Chromebook he does school Zoom's with will not connect to WiFi at all despite the Satellite being in the same room. The Satellite shows connected with a "Good" backhaul status when I check it online. What am I missing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK752 - Devices will not connect to satellite
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. Turning the power down to 50% fixed the issue and everything is able to connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Please mark your thread as solved so others know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm also having this same problem but it only started happening in January. Why do I need to lower the radio power when it has been working fine all along? I'm concerned that lowering the power will cause other problems and then I have to troubleshoot and ask forum questions blah blah blah. It was working fine what changed?
