Orbi WiFi 7 RBE973
Reply
Orbi RBK752 compatible with Arris TM1602
MarcSchwartz
Follower
Looking to purchase an RBK752 and my cable provider (Optimum) only supports two voice/data Arris Modems (TM1602 or TM804G) and both are Docsis 3.0. They have not upgraded, nor do they support Docsis 3.1. Has anyone found compatibility issues? Any suggestions?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi RBK752 compatible with Arris TM1602
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Should work fine with Orbi AX
Thank you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 667 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
