- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK753S - Devices keep disconnecting and reconnecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently installed the Orbi RBK753S mesh system with one wireless satellite and one backhauled satellite and while my coverage and speeds have increased over my previous setup, I keep getting notifications from my smart devices throughout the day that they are dropping connection and re-connecting within about a minute of dropping. I'm wondering if this may be due to the satellites passing the devices back and forth between each other or if this may be indicative of a bigger problem? If it's a case of the former, is there a way to lock devices to a specific satellite so it doesn't get passed around and have intermittent connectivity?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK753S - Devices keep disconnecting and reconnecting
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, and IPv6
Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the response!
I'm on v3.2.18.1_1.4.14 and including the basement it's about 2450 square feet. I have Metronet Fiber for internet using a Nokia modem (ONT 3FE56389ABBG).
I have one satellite on each floor between the basement, main floor, and second floor on alternating corners of the house so they are at least 30 feet apart. Right now 2.4GHz is set to Auto while 5GHz is set to 48. I usually do not see any neighbor's WiFi networks, though they show up every once in a while but typically one if any.
I will try your suggestions, though I'm not certain what the implications are of some of these settings... ha!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keep us posted...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I made the suggested changes last night before going to bed and it actually made matters significantly worse. Previously, this particular device may give me 1-2 notifications in the matter of 24 hours but just while I was asleep it lost connectivity 6 times. The behavior is the same with it reconnecting within about a minute. We have a WiFi baby monitor that also dropped connection 3 times overnight, which up until last night never had this issue. This August Front Door device is actually in a line of sight with one of the satellites so I know this is not an issue of signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would seem like this forum tries to help you post images and consequently breaks and malfunctions... so here is a link to the screenshot: https://i.imgur.com/TrQZAZA.jpg
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is AX mode enabled or disabled on the RBR?
What is the current CTS value setting?
What channels are you using currently?
- Mark as New
- Bookmark
- Subscribe
- Permalink
AX is enabled for both bands and I have CTS/RTS Threshold set to 2347 as previously suggested for both bands. 2.4GHz was previously set to auto and I switched it last night to 6. 5GHz is currently set to 48.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try disabling AX on 2.4Ghz...
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the sake of troubleshooting, I will give this a shot... however with AX being a main feature of this system I would hope it's not necessary to disable it in order for the system to work properly. Will follow up after some time!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you get access to the beta FW?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I was not aware of a Beta program. Is that something you'd recommend I pursue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lets give that a try at least. Send @Christian_R a PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestion - I have PM'ed him and will await his reply. I appreciate your assistance and diligence!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't gotten a response back regarding the beta firmware yet. Are there any other avenues to request it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for that - I have installed that firmware and will see how things go... so far devices have continued to disconnect and reconnect even with AX turned off on the 2.4 band. Let me know if there are any changes you suggest on the new firmware, otherwise I'll just report back!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Quick question, do you see any Parental Controls on the RBRs web page, if so, can you attach a screen capture for us?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did see Smart Parental Controls mentioned in the firmware notes, but I'm not seeing anything referring to it when I log into the router when I traverse through the different menus. If you tell me specifically where it should be located I can tell you for certain if it's there or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Look under the Basic Tab for Parental Controls menu option?
Or Try under Advanced Tab/Security?
There maybe a Upgrade to Netgear SPC button seen here?
Please check Orbi app to see if anything appears there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope, not seeing anything like in your screenshot or mention of parental controls under Advanced -> Security. The web interface also seems quite a bit slower than before, though I won't complain about that if performance/stability improves - so far my device did not disconnect/reconnect overnight.
https://i.imgur.com/L7B2Ymc.png
- Mark as New
- Bookmark
- Subscribe
- Permalink
@randomtask wrote:I made the suggested changes last night before going to bed and it actually made matters significantly worse. Previously, this particular device may give me 1-2 notifications in the matter of 24 hours but just while I was asleep it lost connectivity 6 times. The behavior is the same with it reconnecting within about a minute. We have a WiFi baby monitor that also dropped connection 3 times overnight, which up until last night never had this issue. This August Front Door device is actually in a line of sight with one of the satellites so I know this is not an issue of signal.
Don't know if it's direclty related, but when I was looking for a smart lock, the August system was one of they ones I was researching. When I research reviews, I look at the NEGATIVE ones first to see if there's any consistent issue that people complain about.
For the August, I opted NOT to go that route because of all the reviews complaining about how it consistently drops connection to the network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A valid observation, but it has been rock solid up until I replaced my Nighthawk with the Orbi system. Not only that, but there are several devices that have been exhibiting this behavior - the August was just the only device that I had a simple way of conveying the behavior via the app's push alerts.
Other devices that have exhibited dropping connection include my Nintendo Switch, Wemo light switches/smart plug, Amazon Echo Dots (2-3 at various locations throughout the house), and a Craftsman Garage Door opener (I have two and one specifically would keep dropping/reconnecting).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, thanks for checking.
Will see if NG can provide some information on this.
@randomtask wrote:Nope, not seeing anything like in your screenshot or mention of parental controls under Advanced -> Security. The web interface also seems quite a bit slower than before, though I won't complain about that if performance/stability improves - so far my device did not disconnect/reconnect overnight.
