- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK753S and AT&T help
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have att fiber with the Arris bgw210 modem/router.
I am trying to figure out how to connect the orbi properly.
I still want access to the att arris wifi so that certain devices don't get connected to the orbi and then other devices go to the orbi.
I can't figure it out for the life of me.
I've read everything and not sure what to do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK753S and AT&T help
You have a couple options if you want to keep the att wifi running.
1. put the orbi's IP address in the att devices dmz
2. put the orbi in access point mode. This disables its router functions and lets the att device run them. You can still use the orbi for wifi and ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to visit the Orbi AX Forum for additional help and information:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Slightly confused on this step, on the att setup page, I'm assuming I go to the IP Passthrough then I have options:
Allocation Mode: Off/Default/Passthrough
Passthrough Mode:DHCPS-dynamic, DHCPS-Fixed, Manual
Passthrough Fixed MAC Address: choose from list
Thanks for all the help
- Mark as New
- Bookmark
- Subscribe
- Permalink
@brsboarder wrote:I have att fiber with the Arris bgw210 modem/router.
Do what @plemans posted, then name your Orbi WIFI SSID different than your Arris router's WIFI. You will then have 2 separate identifiable WIFI networks.
