- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK753S won't connect with Epson Workforce 645 printer
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
We have an older Epson Workforce 645, which connected fine to our old Netgear dual band wireless router. We swithced to the Orbi and every device in the house is working on the 5 GHz network with good coverage at 200+ speeds but the printer is not connecting (signal strength is not the issue). It sees three separate networks with the same name but none of them will allow the printer to correctly connect. I did some research since this seems to be a common issue with Epson and changed the 2.4 GHz channel to 1,6, and 11 but that didn't solve the issue. The printer will work if connect by ethernet to the satellite but it's not an ideal location for the satellite and gives lower speeds at that location so that would be the very last resort... Firmware Version V3.2.16.6_1.4.4
I found this old link about connecting an Epson Workforce 845 printer but I have tried to figure out where to click for the fast roaming, Mu-MIMO, and beamforming checkboxes are but they are not there when I go to advanced and click on wireless settings like in the pic so I don't know if that can be changed on the router I have? Is there a way to access this?
I called Netgear support and they were zero help and just said try different channels. Help! My spouse is furious we just spent $500 and now we can't print...
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi RBK753S won't connect with Epson Workforce 645 printer
The problem is not the Orbi, but rather the printer. Go into the printer settings and reset.
presstheHomebutton on the control panel to return to the Home menu.
Select Setup, then press OK.Press
select Reset Network Settings, then press OK
Select Yes and press OK, as necessary, to reset the printer's network settings.
Press the Home button to return to the Home menu.
Then go back and configure the WIFI settings on the printer again, to connect to the Orbi WIFI.
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Be sure to post over in the Orbi AX forum for your model Orbi:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
@Liz133916 wrote:We have an older Epson Workforce 645, which connected fine to our old Netgear dual band wireless router. We swithced to the Orbi and every device in the house is working on the 5 GHz network with good coverage at 200+ speeds but the printer is not connecting (signal strength is not the issue). It sees three separate networks with the same name but none of them will allow the printer to correctly connect. I did some research since this seems to be a common issue with Epson and changed the 2.4 GHz channel to 1,6, and 11 but that didn't solve the issue. The printer will work if connect by ethernet to the satellite but it's not an ideal location for the satellite and gives lower speeds at that location so that would be the very last resort... Firmware Version V3.2.16.6_1.4.4
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Enjoy.
