× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
Orbi RBK842 - Can I add Orbi to my AT&T network?
MarkSL
I have AT&T fiber. AT&T provides a combo modem and router box for wired (4 ports) and wireless (Wi-Fi). The network is already set up. Let's call the wireless network "MyATTHome".
What I want to do is purchase the Orbi RBK842 (AX5700) and add it to my AT&T network, so the Wi-Fi network throughout the house is one seamless, MyATTHome network. Can I do this? Is it possible to add the Orbi router and satellite devices to my existing AT&T network so there is only one Wi-Fi SSID in the house?
Or, does Orbi require you to set up a separate Wi-Fi network (SSID), managed by Orbi? If this is true, then I would have two networks in the house; MyATTHome and MyOrbiHome networks. I do not want two networks, if possible.
Thank you,
Mark
Message 1 of 4
Guru
Re: Orbi RBK842 - Can I add Orbi to my AT&T network?
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 4
CrimpOn
Sensei
Not possible, sorry.  If the AT&T WiFi does not provide enough coverage, then you can install an Orbi system and disable the WiFi on the AT&T system. (Turn it off.)  You can certainly give the Orbi the same (exactly) WiFi name (SSID) and password that the AT&T WiFi system currently has.  That way, devices will automatically connect to the Orbi WiFi without having to be reconfigured.  And, should you in the future decide to turn off the Orbi, you can re-enable the AT&T WiFi and devies will switch back without having to be reconfigured.
You will continue to have only one WiFi network.
Since the AT&T is a router, most people would place the Orbi WiFi system in Access Point (AP) mode and let the AT&T router continue to handle device IP assignment, VPN, port forwarding, etc.
I love my Orbi.
Message 3 of 4
MarkSL
Thank you for this reply! I very much appreciate you taking the time to explain this so well.
Best, Mark
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 439 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
