× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
Orbi RBK853 How to block a device from the internet but still connect to the LAN?
Aurigo
Follower
I have an wireless(wifi) HP printer which can be connected to with ease when access control for it is turned off.
When I go into access control(on mobile app as this feature is not available for some reason in the desktop browser control) and click the radio button to disable internet for it, those on the LAN lose connectivity to it.
How do I block the printer from being seen by the internet while still being visible to those devices on the LAN?
I should be able to simply block devices from accessing the WAN. Why is this so hard?
P.S. I have the RBK853 AX6000, not the RBK53 AC3000, but your system doesn't list what I have and won't let me put my actual model in the model field.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
antinode
Guru
Re: Orbi RBK853 How to block a device from the internet but still connect to the LAN?
> I have an wireless(wifi) HP printer [...]
   Thanks for that detailed description.
   What led you to believe that your (unspecified) "an wireless(wifi) HP
printer" _can_ be "seen by the internet"?  Is there some actual problem
which you are trying to solve?
> I should be able to simply block devices from accessing the WAN. [...]
   There's a fundamental difference between "being seen by the internet"
and "accessing the WAN".
> [...] Why is this so hard?
   "I don't know how to do this" and "Doing this is hard" are spelled
differently for a reason.
   If (for whatever reason) you actually want to prevent your
(unspecified) "an wireless(wifi) HP printer" from accessing the
Internet, then you might try this radical concept (which works for some
people):
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for
"Block services from the Internet".
   Because that feature uses the LAN IP address of the device being
restricted, you'd also want to reserve an address for your (unspecified)
"an wireless(wifi) HP printer".  For that, look for "Address
Reservation".
   Whether that would do anything useful for you is another question.
Message 2 of 3
Guru
https://community.netgear.com/t5/Orbi-AX/How-do-I-block-a-device-from-being-seen-by-the-internet-whi...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 304 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
