- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR350 ethernet not working with wifi OK
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model RBR350 Firmware V4.4.0.10_2.10.63
Successfully set up with (PPoE) VLan and wifi performance is as good as native internet connection.
But i cannot get hardwire ethernet connection to work at all. (appeared to work for a very short time at initial startup)
In some cases (on PC) just plugging in the ethernet cable will stop all connections, including wifi.
Diganostics on the connection from windows does not find a problem.
On the surface is looks like those devices with both ethernet and wifi connections will not work. (PC, Laptop, satellite box)
The same connection path (via switch) to a NAS is OK
Looks similar to post (Orbi rbr350 connected using wifi but wont connect wired) from July this year.
Was a new version of the firmware made avialable?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Further update on this issue.
i have just received a Beta firmware update for trial.
Looks to have fixed the problem, all working as expected now.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR350 ethernet not working with wifi OK
Check NGs download site for FW updates:
https://www.netgear.com/support/product/rbk352.aspx#download
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, have just done a full reset and setup.
Problem is still there.
Also checked firmware versions - all up to date.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I commend you contact NG support and ask for help and information regarding this. Ask about an RMA. Seems that the RBR maybe faulty and needs replaced.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you get this resolved? I have similar issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi , issue yet to be resolved. Raised this problem with Netgear and had confirmed as a known problem. Waiting for firmware update to resolve. I have reconfigured my device as an AP and it seems to work ok but disappointed that will not work as I originally wanted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Glad NG got it fixed.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Contacted support. Provided all the basic troubleshooting performed and linked the 3 different posts on this issue. No update today. Suspect a few people are spending their holidays troubleshooting this after getting the orbis as Xmas presents like me.
Anyone have the rumored beta firmware that resolves this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes have the beta firmware, installed and working OK
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to contact NG support and ask for the beta FW.
https://my.netgear.com/support/contact.aspx
@Whitie25 wrote:
Is there a link to the beta firmware? If not, would you be comfortable to email it to me?
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK By me to email a copy.
Can't guarantee that your issue was the same as mine though!
- Mark as New
- Bookmark
- Subscribe
- Permalink
can you send me a copy of the firmware too?
i just brought my orbi few days ago and i am having the same issue too.
feeling extremely disappoint to netgear's product...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Beta firmware resolves the issue. I'm running it now. But yes you will need to contact Netgear for the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just wanting to post here saying I had the same problem almost 2 months ago now, found this post straight away and it's taken that almost 2 months (including my original ticket being closed after they said they'd get back to me with the workaround) to finally get the beta firmware sent to me which fixed the problem instantly. As a note to netgear support, it may pay to have this as your first point since it's a known problem with this model, especially when the user asks specifically for the firmware when they know it exists, or just take it out of beta since the most recent (broken) firmware was released well over 6 months ago.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would you be able to email me the beta please? My hardware is in warranty but apparently my complimentary support is outdated so I can't contact Netgear to get it. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
