× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
Orbi RBR750 Forwarding Ports
davisfam95
Tutor
I am trying to figure out how to solve the double NAT problem on my gaming consoles and was wondering the best way to port forward for Orbi. I am using the RBS750 Orbi Satellite upstairs away from the main modem and RBR750.
Thank you!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 6
ant
Prodigy
Prodigy
Re: Orbi RBR750 Forwarding Ports
Double NATs? What's the other one using NAT beside your Orbi's?
Message 2 of 6
Guru
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? if so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thank you!
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 3 of 6
davisfam95
Tutor
My Xfinity Modem/Router
Message 4 of 6
davisfam95
Tutor
My family uses an Xfinity modem/router
Model:TG3482G
Vendor:ARRIS Group, Inc.
Yes I have been on bridge mode and it has been better but I still get Double NAT I would say 1/4 times I test the NAT type on my xbox one S.
Thank you again for your response!
Message 5 of 6
Guru
Setup a IP address reservation ON the RBR for the xbox when it ON. When you go save and apply the setting, hold the front power button on the xbox until it shuts OFF. Be usre uPnP is enabled on the RBR and no other port foward configurations are enabled. After the RBR has saved the change and rebooted, power ON the xbox. Check NAT status on the networking dashboard.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 522 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
