Orbi WiFi 7 RBE973
Reply
Orbi RBR750 Router & 2 Satellites - One Satellite bearing the full load.
mattybme
I had some troubles with my RBR 750 a week or so and support requested I flash the firmware and then perform a shock reset on the rotuer. This I performed and things seem to be working but I am seeing one of the two satellites is carrying the entire load. All connected devices are going through the one, not the router and not the other satellite. Anything I should be doing to disperse the devices across all three?
Message 1 of 10
Guru
Re: Orbi RBR750 Router & 2 Satellites - One Satellite bearing the full load.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Message 2 of 10
mattybme
Firmware version is Firmware: 4.6.5.14_2.9.54
Verizon Fios G3100 is the ISP and Router. Orbi Router in AP Mode.
I have not moved those satellites since the troubles began. One is about 50 ft from Router on same floor and the other is about 30 ft from Router one floor above.
Hmm we just lost internet and the Router updated the Wifi/Network name to Admin but with same password. Never seen that before. I am back up.
Message 3 of 10
Guru
Does the front LED turn on PINK with this happens on the RBR?
Is the wifi disabled on the host ISP router?
Message 4 of 10
mattybme
When we had the outage blip this morning yep the ring on the Orbi router was pink/magenta.
Wifi is disabled on the Fios Router and Orbi Router is setup in AP Mode.
House sq footage is 2,848.
Message 5 of 10
Guru
If you turn OFF the RBS and leave just the RBR running, does this still happen?
When you set up the RBR for AP mode, did you set Dynamic or set a Static IP address configuration on the RBR?
Message 6 of 10
mattybme
No Dynamic or Static IP set on the Orbi Router no. If I turn off both RBS the devices connect to the RBR.
Message 7 of 10
Guru
For AP mode there are two modes to get the IP configuration, Dynamic or Static.
Are you sure the RBR is in AP mode or is it in router mode?
Message 8 of 10
mattybme
Oh sorry yes the IP config is Dynamic. Sorry I was thinking Dynamic DNS which is not configured.
Screen Shot 2022-03-14 at 10.56.20 AM.pngScreen Shot 2022-03-14 at 10.56.10 AM.png
Message 9 of 10
Guru
So turn one RBS, the one that isn't seeming to take the full load and see what connects to it.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 955 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
