Orbi WiFi 7 RBE973
Reply
Orbi RBR850 V3.2.18.1 DHCP Assigning IPs every few seconds
CrimpOn
Guru
Re: Orbi RBR850 V3.2.18.1 DHCP Assigning IPs every few seconds
@giubio wrote:
No way: conection to internet absolutely unstable because the IP address of the devices changes many times per day.
When the Orbi is in router mode and devices have been assigned IP addresses by entering their MAC address into the LAN Setup Table (Advanced Tab, Setup, LAN Setup menu) every device should get the same IP address every time.
Message 26 of 30
giubio
My RBR850 is running in Access Point mode since by (my) experience is working better than the router mode, so what you suggest seems non applicable.
I am now trying to work with a static IP for each device in my local net and see what happen.
I will report the results after a pair of days
Message 27 of 30
Mikey94025
Hero
@CrimpOn wrote:
What a puzzle!  I collect the logs from my (original) Orbi and there are no log entries that start with Jan 01, or contain -5:00.
This is yet another example of the frustration customers face when their Netgear product behaves strangely and there is no documentation or customer service contact to explain it.
Another datapoint - My RBR850 running the Beta firmware V3.2.18.223 (to fix the DNS bug) does include these mysterious Jan 01 log entries.  I collect all the Netgear logs in my gmail and see that these Jan 01 log entries have appeared for a long time, e.g., a log from Feb 5 also includes them.
From 20h ago:
[LAN access from remote] from 185.193.88.167 port 53162 to 192.168.1.55 port 3389 Sunday, Jul 04,2021 14:19:22
 Thursday, Jan 01,491926 -8:00:00
Message 28 of 30
Guru
Please report any data point findings in the v223 beta forum thread so NG is aware of what your finding.
Thank you.
From 20h ago:
Message 29 of 30
FarmerBob1
Luminary
For ages my Logs have start with similar lines of text. Not sure, but I'll have to check if the sequence is the same.
Message 30 of 30
Top Contributors
Discussion stats
  • 29 replies
  • 3074 views
  • 1 kudo
  • 9 in conversation
Announcements
Orbi WiFi 7
