- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR850 with Centurylink Fiber
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Everyone,
I have a question. I am changing my Dads router to the Orbi RBR850 with Centrylink. Previous the router was at my house where I had no problems, only diff is that I have Xfinity.
I have tried to configure the PPOE setting with the correct user name and password however no luck. I tells me that it can non find the internet.
There is no Modem since its fiber so eveything coming into the house in COAX with CAT 5 cabeling coming into a switch at the juncion box and then lighting up the ports in the house.
Help would be appreciated.
Mike
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know. Please mark your thead and solved so others will know.
Enjoy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR850 with Centurylink Fiber
I would also ensure your using good quality LAN cables. CAT6 is recommended.
What is the Mfr and model# of the ONT the RBR is connected too?
Does using DHCP instead of PPPoE result in any difference?
Try powering OFF both RBR and ONT for 30 seconds then back ON.
I would contact the ISP and ask for help and information on this. Possible that PPPOE may not be needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same setup, and I couldn't connect the Orbi router directly to the ONT (the Optical Network Terminal, the box the fiber connection goes to). You need something in between the ONT and the Orbi to handle VLAN tagging.That could be a modem, but it can also just be a network switch. Just make sure you get one that handles VLAN tagging -- I bought a ProSafe switch and that did the trick.
Here's an article on it: https://www.dslreports.com/forum/r31043915-How-to-almost-use-any-router-with-CenturyLink-s-1-Gig-Int...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
@mrymk wrote:Hello Everyone,
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Call Centurylink for your pppoe username and password and vlan number which is (201)
Have laptop and ethernet wire
Log on to orbilogin.net
On Basic tab
Make sure you have to the most updated firmware on your router and satellite
Once you determine your software is up to date
Enter your internet service provider pppoe and password
Go into your Advanced tab
Advance setting change to vlan to 201
Follow orbi instruction on set up
Your internet should connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is awesome, thanks for reporting back. I just configured mine the same way and cut out the switch in the middle. One less device to worry about!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed. Enjoy.
